    Jellyfin Forum Support Troubleshooting Media Scanning & Identification SOLVED: Sorting / identify Problem
    some Anime Movies can only be seen in Episode tab
    zwiebl
    2023-08-16, 06:00 PM (This post was last modified: 2023-08-16, 06:02 PM by zwiebl. Edited 1 time in total.)
    Hello guys! just recently set up my jellyfin server and overall i am very happy.
    So i made an Anime library with all my anime stuff. most got picked up correctly. some i had to do manually by clicking identify and adding the imbd id. worked great.
    but a few movies like Howls moving castle, porco rosso, castle in the sky do ONLY show when i click to episode tab (and on recently added). no metadata found for these and i cannot click identify to link imdb id. i tried editing metadata and added "Sort title"... i was hoping then it would show on "shows" tab and i can identify it... but it never shows on "shows" tab, only on episode. now i am looking for some help. running jellyfin 10.8.10 on windows 10
    how can i identify these? or how can i make em show on shows tab?
    2023-08-16, 06:14 PM
    It sounds like you are putting movies into a TV Show library? You should separate movies into a movie type library. Otherwise it will have trouble identifying them.
    zwiebl
    2023-08-16, 07:46 PM
    oh. thanks for the response! didnt think of that... because all the other movies like my neighbour totoro, when marnie was there, and others are getting shown at "shows" and i could identify them if data was not found.
    its just 4 movies that are stuck in eposides... is there really no way to move them to shows and identify them? do i really have to make 2 separat libraries? sadface
    Venson
    Moderater Team Moderator
    Threads: 7
    2023-08-16, 08:09 PM
    Hey @zwiebl
    Yes you more or less have to. Jellyfin uses the Lib type to "talk" to the correct metadata providers.
    There is a mixed type, but it has tones of bugs itself and is considered obsolete/legacy only.
    typos are finders, keepers.
    2023-08-16, 08:10 PM (This post was last modified: 2023-08-16, 08:11 PM by TheDreadPirate. Edited 2 times in total.)
    I haven't seen anyone get a mixed movie/TV library to work well in Jellyfin.
    ***See Venson's response.
    zwiebl
    2023-08-16, 08:16 PM
    thanks for the quick and good answers!
    i will make 2 libraries
