    Jellyfin Forum Support Troubleshooting Startup problem jellyfin-web
    Pages (3): « Previous 1 2 3
    There is no way to start the service Jellyfin
    AEZAKMI
    Country:Turkey
    #21
    2023-11-25, 05:58 PM
    (2023-11-24, 06:28 PM)TheDreadPirate Wrote: Honestly, I have no idea what is causing jellyfin to not start.  Sorry.
    Can you tell me I did, sudo systemctl start jellyfin.service earned well there is no access to the web version
    sudo systemctl status jellyfin.service
    ● jellyfin.service - Jellyfin Media Server
        Loaded: loaded (/lib/systemd/system/jellyfin.service; enabled; preset: enabled)
        Drop-In: /etc/systemd/system/jellyfin.service.d
                └─jellyfin.service.conf
        Active: active (running) since Sat 2023-11-25 22:54:27 +05; 1s ago
      Main PID: 2470 (jellyfin)
          Tasks: 1 (limit: 4467)
        Memory: 888.0K
            CPU: 15ms
        CGroup: /system.slice/jellyfin.service
                └─2470 /usr/bin/jellyfin --webdir=/usr/share/jellyfin/web --restartpath=/usr/lib/jellyfin/restart.sh --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg
    ноя 25 22:54:27 nas jellyfin[2457]:    at Jellyfin.Server.Program.<Main>(String[] args)
    ноя 25 22:54:27 nas jellyfin[2457]: Unhandled exception. System.UnauthorizedAccessException: Access to the path '/etc/jellyfin' is denied.
    ноя 25 22:54:27 nas jellyfin[2457]:  ---> System.IO.IOException: Permission denied
    ноя 25 22:54:27 nas jellyfin[2457]:    --- End of inner exception stack trace ---
    ноя 25 22:54:27 nas jellyfin[2457]:    at System.IO.FileSystem.CreateDirectory(String fullPath)
    ноя 25 22:54:27 nas jellyfin[2457]:    at System.IO.Directory.CreateDirectory(String path)
    ноя 25 22:54:27 nas jellyfin[2457]:    at Jellyfin.Server.Program.CreateApplicationPaths(StartupOptions options)
    ноя 25 22:54:27 nas jellyfin[2457]:    at Jellyfin.Server.Program.StartApp(StartupOptions options)
    ноя 25 22:54:26 nas systemd[1]: jellyfin.service: Failed with result 'signal'.
    ноя 25 22:54:27 nas systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 13.
    ноя 25 22:54:27 nas systemd[1]: Stopped jellyfin.service - Jellyfin Media Server.
    ноя 25 22:54:27 nas systemd[1]: Started jellyfin.service - Jellyfin Media Server.
    jaiovi
    Country:Mexico
    #22
    2024-07-10, 03:56 PM
    (2023-11-22, 03:51 PM)TheDreadPirate Wrote: If this is a fresh install and you don't care about losing anything, follow these steps.
    sudo apt purge jellyfin
    After that second command finishes, it should start the jellyfin service.  Literally that easy.
    To stop Jellyfin
    sudo systemctl stop jellyfin
    To start Jellyfin
    Jellyfin will automatically start on reboots.
    I've got the same issue, but really I want to keep it. I restarted my server from web (button), but failed to restart. (jellyfin.org)
