    Jellyfin Forum Support Troubleshooting Subtitle problem
    Subtitle problem
    Subtitle Issues in Jellyfin After Ripping with HandBrake
    Micky
    Country:Spain
    2024-12-03, 07:29 PM
    Good afternoon, everyone.
    I'm having trouble displaying subtitles for some movies that were previously ripped with HandBrake.
    I'm not sure if this has been happening for a while, as I just noticed the issue.
    What I can confirm is that the subtitles are recognized by Jellyfin (they all appear listed, and I can select them), and when opening the movies locally with VLC, all the subtitles display correctly. The same movies, when not processed through HandBrake, show subtitles properly in Jellyfin.
    Does anyone know if this is a bug or have any ideas on how to fix it?
    Thank you very much in advance.
    2024-12-03, 09:23 PM
    What kind of subtitles are they? Can you share the media info from the file not processed by handbrake and the file that IS processed by handbrake?
    Micky
    Country:Spain
    2024-12-05, 12:50 PM
    (2024-12-03, 07:29 PM)Micky Wrote: Good afternoon, everyone.
    Thanks for the help.
    Info from the original media:
    Text #1
    Format                      : UTF-8
    Codec ID                    : S_TEXT/UTF8
    Codec ID/Info              : UTF-8 Plain Text
    Duration                    : 21 min 12 s
    Bit rate                    : 4 b/s
    Count of elements          : 27
    Stream size                : 734 Bytes (0%)
    Title                      : European Spanish (Forced)
    Language                    : Spanish
    Default                    : Yes
    Forced                      : Yes
    Text #2
    Format                      : UTF-8
    Duration                    : 28 min 28 s
    Bit rate                    : 73 b/s
    Count of elements          : 502
    Stream size                : 15.3 KiB (0%)
    Language                    : Spanish
    Default                    : No
    Forced                      : No
    Text #3
    Format                      : UTF-8
    Duration                    : 27 min 37 s
    Bit rate                    : 87 b/s
    Count of elements          : 534
    Stream size                : 17.7 KiB (0%)
    Language                    : Spanish
    Default                    : No
    Forced                      : No
    Text #4
    Format                      : UTF-8
    Duration                    : 27 min 44 s
    Bit rate                    : 98 b/s
    Count of elements          : 593
    Stream size                : 20.1 KiB (0%)
    Title                      : European Spanish (SDH)
    Language                    : Spanish
    Default                    : No
    Forced                      : No
    Text #5
    Format                      : UTF-8
    Duration                    : 28 min 27 s
    Bit rate                    : 71 b/s
    Stream size                : 14.9 KiB (0%)
    Language                    : Catalan
    Default                    : No
    Forced                      : No
    Text #6
    Format                      : UTF-8
    Duration                    : 28 min 32 s
    Bit rate                    : 105 b/s
    Count of elements          : 618
    Stream size                : 22.1 KiB (0%)
    Title                      : SDH
    Language                    : English
    Default                    : No
    Forced                      : No
    Text #7
    Format                      : UTF-8
    Bit rate                    : 67 b/s
    Count of elements          : 494
    Stream size                : 14.1 KiB (0%)
    Language                    : Basque
    Default                    : No
    Forced                      : No
    Text #8
    Format                      : UTF-8
    Bit rate                    : 75 b/s
    Count of elements          : 479
    Stream size                : 15.7 KiB (0%)
    Language                    : Galician
    Default                    : No
    Forced                      : No
    Info from the ripped media:
    Text #1
    Format                      : ASS
    Codec ID                    : S_TEXT/ASS
    Codec ID/Info              : Advanced Sub Station Alpha
    Duration                    : 26 min 48 s
    Compression mode            : Lossless
    Language                    : Spanish
    Default                    : Yes
    Forced                      : Yes
    Text #2
    Format                      : ASS
    Duration                    : 28 min 47 s
    Language                    : Spanish
    Default                    : No
    Forced                      : No
    Text #3
    Format                      : ASS
    Duration                    : 27 min 57 s
    Language                    : Spanish
    Default                    : No
    Forced                      : No
    Text #4
    Format                      : ASS
    Duration                    : 28 min 1 s
    Language                    : Spanish
    Default                    : No
    Forced                      : No
    Text #5
    Format                      : ASS
    Language                    : Catalan
    Default                    : No
    Forced                      : No
    Text #6
    Format                      : ASS
    Duration                    : 28 min 38 s
    Title                      : SDH
    Language                    : English
    Default                    : No
    Forced                      : No
    Text #7
    Format                      : ASS
    Language                    : Basque
    Default                    : No
    Forced                      : No
    Text #8
    Format                      : ASS
    Language                    : Galician
    Default                    : No
    Forced                      : No
    2024-12-05, 02:10 PM (This post was last modified: 2024-12-05, 02:10 PM by TheDreadPirate. Edited 1 time in total.)
    Handbrake is converting the SRT subs to ASS? There is a setting in Handbrake to passthrough the subtitles unmodified.
    Do you have transcoding disabled? I'm wondering if your clients don't support ASS subs and are trying to burn them in.
    Can you share your jellyfin log for pastebin so we can confirm what is happening server side? And what are your hardware specs for the server.
    Micky
    Country:Spain
    2024-12-05, 05:02 PM
    (2024-12-05, 02:10 PM)TheDreadPirate Wrote: Handbrake is converting the SRT subs to ASS?  There is a setting in Handbrake to passthrough the subtitles unmodified.
    Log: Pastebin
    Indeed, I didn’t configure HandBrake to keep the subtitles in SRT format. When I tried ripping while maintaining the subtitle format, they were preserved.
    Now I have the question/need to know if I can configure something on the Jellyfin side so that, even if the subtitles are in ACC format, they can still be viewed on my browser (Brave), Android TV, or Android app. I have Jellyfin running in a Docker on UNRAID, and my hardware is an i9 13900k without a dedicated graphics card. I’m also attaching screenshots of my transcoding configuration in case it’s relevant.
    Another option, if possible, would be to rip all the videos while only changing the subtitle format. However, since I usually only use HandBrake, I don’t think it’s possible—I’m not sure which tool could be used for this.
    Transcoding settings
    2024-12-05, 05:24 PM (This post was last modified: 2024-12-05, 05:25 PM by theguymadmax. Edited 1 time in total.)
    HandBrake converts SRT files to SSA (Substation Alpha) format for MKV files and to timed text for MP4 files. The Android TV client cannot directly play SSA subtitles and will instead burn them into the video.
    SRT Subtitles
    • Please note, SRT tracks are converted to SSA in the output file. This behavior is not currently configurable.
    2024-12-05, 05:33 PM
    In the decode list check all the codecs except VP8.
    Also check both tone mapping boxes. As long as you have the OpenCL mod installed in your container.
    You SHOULD be using passthrough for the subtitles. Don't bother letting Handbrake convert them to SSA or timed text. Just keep them as SRT. You gain nothing from the conversion.
    Handbrake does allow you to create custom presets and you can include in that preset that it always pass through the subtitles unmodified.
    2024-12-05, 05:59 PM
    (2024-12-05, 05:33 PM)TheDreadPirate Wrote: You SHOULD be using passthrough for the subtitles.  Don't bother letting Handbrake convert them to SSA or timed text.  Just keep them as SRT.  You gain nothing from the conversion.
    I've tried passing through SRT files in HandBrake, but it always converts them to SSA. Could you share the settings you use? I typically extract the SRT files beforehand and keep them as external files.
    2024-12-05, 06:26 PM (This post was last modified: 2024-12-05, 06:29 PM by TheDreadPirate.)
    I don't use Handbrake anymore, but I still have my preset saved as a json export.
      "PresetList": [
          "AlignAVStart": false,
          "AudioCopyMask": [
            "copy:aac",
            "copy:ac3",
            "copy:dtshd",
            "copy:dts",
            "copy:mp3",
            "copy:truehd",
            "copy:flac",
            "copy:eac3",
            "copy:mp2"
          "AudioEncoderFallback": "av_aac",
          "AudioLanguageList": [
            "any"
          "AudioList": [
              "AudioBitrate": 512,
              "AudioCompressionLevel": 0,
              "AudioEncoder": "copy",
              "AudioMixdown": "7point1",
              "AudioNormalizeMixLevel": false,
              "AudioSamplerate": "auto",
              "AudioTrackQualityEnable": false,
              "AudioTrackQuality": -1,
              "AudioTrackGainSlider": 0,
              "AudioTrackDRCSlider": 0
          "AudioSecondaryEncoderMode": false,
          "AudioTrackSelectionBehavior": "all",
          "ChapterMarkers": true,
          "ChildrenArray": [],
          "Default": true,
          "FileFormat": "av_mkv",
          "Folder": false,
          "FolderOpen": false,
          "Mp4HttpOptimize": false,
          "Mp4iPodCompatible": false,
          "PictureCropMode": 0,
          "PictureBottomCrop": 22,
          "PictureLeftCrop": 272,
          "PictureRightCrop": 274,
          "PictureTopCrop": 22,
          "PictureDARWidth": 0,
          "PictureDeblockPreset": "off",
          "PictureDeblockTune": "medium",
          "PictureDeblockCustom": "strength=strong:thresh=20:blocksize=8",
          "PictureDeinterlaceFilter": "off",
          "PictureCombDetectPreset": "off",
          "PictureCombDetectCustom": "",
          "PictureDenoiseCustom": "",
          "PictureDenoiseFilter": "off",
          "PictureSharpenCustom": "",
          "PictureSharpenFilter": "off",
          "PictureSharpenPreset": "medium",
          "PictureSharpenTune": "none",
          "PictureDetelecine": "off",
          "PictureDetelecineCustom": "",
          "PictureColorspacePreset": "off",
          "PictureColorspaceCustom": "",
          "PictureChromaSmoothPreset": "off",
          "PictureChromaSmoothTune": "none",
          "PictureChromaSmoothCustom": "",
          "PictureItuPAR": false,
          "PictureKeepRatio": true,
          "PicturePAR": "auto",
          "PicturePARWidth": 0,
          "PicturePARHeight": 0,
          "PictureUseMaximumSize": false,
          "PictureAllowUpscaling": false,
          "PictureForceHeight": 0,
          "PictureForceWidth": 0,
          "PicturePadMode": "none",
          "PicturePadTop": 0,
          "PicturePadBottom": 0,
          "PicturePadLeft": 0,
          "PicturePadRight": 0,
          "PresetDescription": "",
          "PresetName": "Blu-ray HEVC NVENC slow CQ26",
          "Type": 1,
          "SubtitleAddCC": false,
          "SubtitleAddForeignAudioSearch": false,
          "SubtitleAddForeignAudioSubtitle": false,
          "SubtitleBurnBehavior": "none",
          "SubtitleBurnBDSub": false,
          "SubtitleBurnDVDSub": false,
          "SubtitleLanguageList": [
            "any"
          "SubtitleTrackSelectionBehavior": "all",
          "VideoAvgBitrate": 0,
          "VideoColorMatrixCode": 0,
          "VideoEncoder": "nvenc_h265",
          "VideoFramerateMode": "cfr",
          "VideoGrayScale": false,
          "VideoScaler": "swscale",
          "VideoPreset": "slow",
          "VideoTune": "",
          "VideoProfile": "auto",
          "VideoLevel": "auto",
          "VideoOptionExtra": "",
          "VideoQualityType": 2,
          "VideoQualitySlider": 26,
          "VideoTwoPass": false,
          "VideoTurboTwoPass": false,
          "x264UseAdvancedOptions": false,
          "PresetDisabled": false,
          "MetadataPassthrough": true
      "VersionMajor": 50,
      "VersionMicro": 0,
      "VersionMinor": 0
    I'll have to double check if this preset works on SRT subs. IIRC, all my files I ran through handbrake had PGS or DVDSUB subtitles.
