    Jellyfin Forum Support General Questions The burn-in subtitles will become semi-transparent when enable hardware acceleration
    gnattu
    #11
    2024-11-14, 03:17 PM
    Now I doubt if it is a hardware or firmware bug of your specific iGPU handling the alpha channels.
    Giresharu
    2024-11-14, 04:23 PM (This post was last modified: 2024-11-14, 08:25 PM by Giresharu. Edited 2 times in total.)
    (2024-11-14, 01:51 PM)Fate Wrote:
    (2024-11-14, 08:34 AM)Giresharu Wrote: This issue does not provide any relevant log information, and it only reproduces on my server. And I’ve reinstalled Jellyfin many times.
    What should I do now?
    Can you elaborate on which system your jellyfin run at and which distro you are using? Kernel Version?
    Intel arc is still a bit new so there still could be some driver bugs left.
    The kernel version inside both the host and the container are:
    Linux NAS 6.1.0-27-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.115-1 (2024-11-01) x86_64 GNU/Linux
    I am now preparing to try installing it directly on Debian without using Docker, to see if there is any difference.
    After testing, the same situation occurs when directly installed on the host. Maybe I should look for clues related to Intel drivers.
    Fate
    #13
    2024-11-15, 12:02 AM
    Any chance you could try something newer?
    Like ubuntu 24.10 or manjaro with the 6.11 kernel?
    Giresharu
    2024-11-15, 02:02 PM (This post was last modified: 2024-11-15, 02:37 PM by Giresharu. Edited 1 time in total.)
    Should I try change the host system environment, or should I switch to a Jellyfin image that uses Ubuntu as its environment?
    It’s not convenient for me to change the host system environment.
    2024-11-15, 03:27 PM
    Do your debian sources pull from non-free and non-free-firmware?
    Giresharu
    2024-11-16, 04:21 PM
    (2024-11-15, 03:27 PM)TheDreadPirate Wrote: Do your debian sources pull from non-free and non-free-firmware?
    I installed from the complete DVD ISO image downloaded from the Debian official website.
    2024-11-16, 08:55 PM
    I meant the configs in /etc/apt/sources.list.d/. Your sources would need "non-free" and "non-free-firmware" in the component list. I believe those two components are not included due to Debian only allowing "free" packages, by default.
    deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
    Giresharu
    2024-11-17, 07:34 PM
    (2024-11-16, 08:55 PM)TheDreadPirate Wrote: I meant the configs in /etc/apt/sources.list.d/.  Your sources would need "non-free" and "non-free-firmware" in the component list.  I believe those two components are not included due to Debian only allowing "free" packages, by default.
    Do you mean "/ect/apt/sources.list.d/docker.list"?
    It is:
    deb [arch=amd64 signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/debian  bookworm stable
    Or "debian.sources"?
    It is:
    Types: deb
    URIs: http://deb.debian.org/debian
    Suites: bookworm bookworm-updates
    Components: main contrib non-free-firmware non-free
    Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg
    Types: deb
    URIs: http://deb.debian.org/debian-security
    Suites: bookworm-security
    2024-11-17, 08:14 PM
    debian.sources. And it looks like you have all the non-free repos, so that's removes that as a factor.
    Giresharu
    2024-12-12, 04:36 PM
    Recently, I finally had the opportunity to switch my system to Ubuntu 24.04.1 LTS, and I reinstalled the Jellyfin container in Docker with hardware acceleration enabled. The same issue can still be triggered. This seems to suggest that the problem is not due to the system itself.
