    Jellyfin Forum Support General Questions Tone Map Dolby Vision to SDR using 100-nit L2 Trim
    Does Jellyfin use Dolby Vision's 100-nit L2 Trim when tone mapping Dolby Vision media to Rec. 709 SDR?
    Speedy
    2023-12-23, 02:10 AM (This post was last modified: 2023-12-23, 08:23 AM by Speedy. Edited 4 times in total.)
    It seems like the L1 metadata is being used, but not whether the L2 or L8 trims are being used.
    Is this limited to specific color spaces? e.g., does it do it for both the IPTPQc2 (Profile 5) and YCbCr (Profile 7 & 8 color spaces?
    I've run across the following but neither includes this information:
    • https://github.com/jellyfin/jellyfin-ffmpeg/pull/151
    • https://www.reddit.com/r/jellyfin/commen...is_coming/
    Thank you!
    nyanmisaka
    Online
    2023-12-24, 01:21 PM
    It is not. Currently you can get the free Dolby Vision playback support in open source players/renderers (such as mpv/libplacebo/mpc-be/jellyfin) is limited to the reshaping part of the dynamic metadata, while other parts such as L2 Trim are not yet supported. This already ensures that users will not be troubled by wrong colors when playing Profile 5 videos on SDR screens. You have to understand that there are limits to reverse engineering from the community, and if you want a premium Dolby Vision support buy a certified player and avoid transcoding.
    https://code.videolan.org/videolan/libpl...quests/207
    Speedy
    2023-12-24, 06:20 PM (This post was last modified: 2023-12-24, 06:20 PM by Speedy. Edited 1 time in total.)
    (2023-12-24, 01:21 PM)nyanmisaka Wrote: Currently you can get the free Dolby Vision playback support in open source players/renderers (such as mpv/libplacebo/mpc-be/jellyfin) is limited to the reshaping part of the dynamic metadata
    @nyanmisaka thanks for the reply!
    Just to confirm in technical language... when you say "limited to the reshaping part of the dynamic metadata", is Jelyfine (and other open source projects like mpv) currently only utilizing the L1 metadata and determining/interpolating tone mapping based on that (this seems very similar to how HDR10+ metadata would typically be used.
    Quote:L1 – Level 1 – (min, avg, max):
    The Dolby Vision analysis produces three values per shot (or per frame) to describe the image and its dynamic range.
    Thanks!
    Speedy
    2024-01-22, 09:49 PM
    Bumping my previous message/question
