    Jellyfin Forum Support Troubleshooting Transcode doesn't work on web
    It appears that the my transcoder doesn't work only on certain titles only using the web.
    monointent
    2024-07-15, 01:33 AM
    Hello all, I seek help
    I am running an Arc gpu through a kube cluster.
    When viewing certain titles through the web GUI, it will prompt for a transcode issue or just spin indefinitely.
    When viewing the same media on the same machine but using the app from the GitHub, it plays just fine and I can adjust the playback settings.
    I am not sure if there is a miss-config somewhere.
    I have attached the logs, any help would be greatly appreciated.
    .txt   Jellyfin Logs.txt (Size: 11.75 KB / Downloads: 145)
    2024-07-15, 01:48 AM
    What kernel is your system running?
    monointent
    2024-07-15, 02:36 AM
    (2024-07-15, 01:48 AM)TheDreadPirate Wrote: What kernel is your system running?
    running uname -r
    on the proxmox host
    $ root@mainframe:~# uname -r
    $ 6.5.11-8-pve
    on the Kube Cluster node
    $ mono@sous3:~$ uname -r
    $ 6.8.0-38-generic
    2024-07-15, 02:47 AM (This post was last modified: 2024-07-15, 02:48 AM by TheDreadPirate.)
    I'm assuming the "kube cluster" is running Ubuntu 24.04. Kernel 6.8.0-38 inherited an upstream kernel driver regression that breaks transcoding. Roll back to 6.8.0-36. There is a ticket in with Ubuntu's kernel team to backport a pair of patches to resolve the issue.
    For now stick with 6.8.0-36.
    https://bugs.launchpad.net/ubuntu/+sourc...ug/2072755
    monointent
    2024-07-15, 02:55 AM
    Ah, okay, thank you! I have been racking my brain and trying so much stuff. appreciate it!
    2024-09-10, 04:55 PM
    Ubuntu released 6.8.0-44 with all the patches that fix this issue.
