    Jellyfin Forum Support Troubleshooting Transcoding 4k Problems
    having issues playing 4k videos
    jawlessemu
    2023-12-03, 10:49 AM
    i dont understand question.
    it does have a jellyfin app but thats all.
    Serge K
    Country:Ukraine
    #12
    2023-12-03, 10:53 AM (This post was last modified: 2023-12-03, 11:30 AM by Serge K. Edited 1 time in total.)
    check settings of jellyfin app - must be possibility to choose/change player
    your hardware is very powerful - it is enough for transcoding of 4k to lower format for your roku tv
    jawlessemu
    2023-12-04, 03:26 PM
    i played the movie through the roku media player and it played just fine. so it must just be the jellyfin app for roku thats the problem. are there any recommendations for a player app besides jellyfin's and the roku one?
    Serge K
    Country:Ukraine
    #14
    2023-12-04, 03:37 PM (This post was last modified: 2023-12-04, 03:37 PM by Serge K.)
    you can use jellyfin playing video with VLC player
    jawlessemu
    2023-12-04, 10:10 PM
    is there a tutorial for this? i searched and didnt find anything clear
    Serge K
    Country:Ukraine
    #16
    2023-12-05, 02:28 PM
    (2023-12-04, 10:10 PM)jawlessemu Wrote: is there a tutorial for this? i searched and didnt find anything clear
    unfortunatelly I dont known Jellyfin for Roku
    You can try to find how to change player in th setting of Jellyfin Roku
    tmsrxzar
    #17
    2023-12-05, 02:42 PM (This post was last modified: 2023-12-05, 02:42 PM by tmsrxzar.)
    if you haven't enabled an option to scale the video to 1080 in the roku Client then the server will not scale
    if you don't have the option in the Client to change scaling then you need to wait for a new version
    barring those 2 things the only option left is to re-encode or use a different client/device to play 4k
    oopsmybad
    2023-12-08, 07:52 PM (This post was last modified: 2023-12-08, 07:53 PM by oopsmybad. Edited 1 time in total.)
    I've also been facing this (or a similar issue).
    I have all TCL Roku TV's in my house. The TVs with 'Roku Ultra' equivalents built in all stream 4k content as expected. Specifically, they show the media in 4k - but if I go into the Jellyfin app's settings and change the bit rate to '1'mbps for example, the movie is transcoded down in resolution, like you would expect:
    Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x1600, SAR 1:1 DAR 12:5, 23.98 fps, 23. 98 tbr, 1k tbn (default)
    Stream mapping:
      Stream #0:0 -> #0:0 (hevc (native) -> hevc (hevc_qsv))
      Stream #0:0: Video: hevc (hvc1 / 0x3163766Nerd-face, qsv(tv, bt709, progressive), 720x300 [SAR 1:1 DAR 12:5], q=2-31, 1000 kb/s, 23.98 fps, 90k tbn (default)
    (You can see I have QSV acceleration enabled, no tone mapping (that's broken with my Synology 918+), and hevc encoding is enabled - but I don't think any of that plays role in the next part).
    Now, on the cheapest TCL Roku TVs (32" 1080p's), doing the same thing -- setting a bandwidth limit to 1mbps - doesn't actually do anything. When I try to stream the same movie as above on that TV, this is what happens:
    Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x1600, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn (default)
    Stream mapping:
      Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_qsv))
      Stream #0:0: Video: h264, qsv(tv, bt709, progressive), 3840x1600 [SAR 1:1 DAR 12:5], q=2-31, 35291 kb/s, 23.98 fps, 90k tbn (default)
    Here, even with the lowest bit rate specififed in the Jellyfin Roku app, it doesn't get transcoded down in resolution (and the bit rate isn't 1mbps). It stays 4k, which the TV doesn't support. (The Roku TVs have Roku built into the hardware - so you don't get the option to specifiy a resolution.)
    It seems like something is awry when it comes to setting a bandwidth limit and the resulting transcoding experience -- but not on all Roku TVs. Just on that one Roku platform (low end TCL).
    Just my observations!
    2023-12-08, 08:13 PM
    (2023-12-08, 07:52 PM)oopsmybad Wrote: Now, on the cheapest TCL Roku TVs (32" 1080p's), doing the same thing -- setting a bandwidth limit to 1mbps - doesn't actually do anything. When I try to stream the same movie as above on that TV, this is what happens:
    Stream mapping:
    This sounds like a bug and you should definitely submit an issue on the Roku app github.
    https://github.com/jellyfin/jellyfin-roku/issues
