    Jellyfin Forum Support Troubleshooting Media Scanning & Identification TVDB Scans Fail Due To "Resource Temporarily Unavailable" Error
    acecabana
    2024-01-11, 09:44 PM
    Is anyone else having issues with scanning media library to add pictures, descriptions, etc? I have the "Scan Media Library" scheduled task set to run every hour and it's been running since I set up my server months ago without issue. Starting two days ago, the task would fail with the following error from the logs. The line that sticks out to me is "Resource temporarily unavailable (api.thetvdb.com:443)". Just wondering if anyone has any info on what might be happening. I checked my tvdb plugin to make sure i have the right API key in there and I do. :
    Quote:[2024-01-11 20:10:46.051 +00:00] [ERR] [49] Emby.Server.Implementations.ScheduledTasks.TaskManager: Error
    System.Net.Http.HttpRequestException: Resource temporarily unavailable (api.thetvdb.com:443)
    ---> System.Net.Sockets.SocketException (11): Resource temporarily unavailable
      at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
      at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)
      at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request)
      at System.Threading.Tasks.TaskCompletionSourceWithCancellation1.WaitWithCancellationAsync(CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
      at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
      at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
      at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
      at TvDbSharper.Infrastructure.ApiClient.SendRequestAsync(ApiRequest request, CancellationToken cancellationToken)
      at TvDbSharper.Clients.AuthenticationClient.AuthenticateAsync(AuthenticationData authenticationData, CancellationToken cancellationToken)
      at Jellyfin.Plugin.Tvdb.TvdbClientManager.GetTvDbClient(String language)
      at Jellyfin.Plugin.Tvdb.TvdbClientManager.<>c__DisplayClass24_0
    1.<<TryGetValue>b__0>d.MoveNext()
      at Microsoft.Extensions.Caching.Memory.CacheExtensions.GetOrCreateAsync[TItem](IMemoryCache cache, Object key, Func2 factory)
      at Jellyfin.Plugin.Tvdb.Providers.TvdbMissingEpisodeProvider.GetAllEpisodes(Int32 tvdbId, String acceptedLanguage, EpisodeQuery episodeQuery)
      at Jellyfin.Plugin.Tvdb.Providers.TvdbMissingEpisodeProvider.HandleSeries(Series series)
      at Jellyfin.Plugin.Tvdb.Providers.TvdbMissingEpisodeProvider.OnProviderManagerRefreshComplete(Object sender, GenericEventArgs
    1 genericEventArgs)
      at MediaBrowser.Providers.Manager.ProviderManager.OnRefreshComplete(BaseItem item)
      at MediaBrowser.Controller.Entities.Folder.ValidateChildrenInternal(IProgress1 progress, Boolean recursive, Boolean refreshChildMetadata, MetadataRefreshOptions refreshOptions, IDirectoryService directoryService, CancellationToken cancellationToken)
      at MediaBrowser.Controller.Entities.Folder.<>c__DisplayClass70_0
    1.<<RunTasks>b__1>d.MoveNext()
      at MediaBrowser.Controller.Entities.Folder.RunTasks[T](Func3 task, IList1 children, IProgress1 progress, CancellationToken cancellationToken)
      at MediaBrowser.Controller.Entities.Folder.ValidateChildrenInternal2(IProgress
      at MediaBrowser.Controller.Entities.AggregateFolder.ValidateChildrenInternal(IProgress
      at Emby.Server.Implementations.Library.LibraryManager.PerformLibraryValidation(IProgress1 progress, CancellationToken cancellationToken)
      at Emby.Server.Implementations.Library.LibraryManager.ValidateMediaLibraryInternal(IProgress
      at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
    [2024-01-11 20:10:46.066 +00:00] [INF] [49] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Scan Media Library" Failed after 0 minute(s) and 3 seconds
    2024-01-11, 10:11 PM
    Is your host's firewall blocking outbound connections on port 443? SELinux?
    tmsrxzar
    2024-01-11, 10:33 PM
    it's just an issue on tvdb's side, nothing to be done
    https://github.com/jellyfin/jellyfin-plu.../issues/48
    acecabana
    2024-01-11, 10:55 PM
    Just closing the loop on this, I restarted my nas and uninstalled/reinstalled thetvdb plugin from the Jellyfin repository and my scans began working again. I had a power outage before this started and I suspect this was a holdover from that. Just needed a reboot.
