    Jellyfin Forum Support Troubleshooting Media Scanning & Identification will my current plex media folder system work in Jellyfin?
    II divide movies for intance by country at the folder level will this work in Jellyfin?
    ChibiDavid
    Country:Australia
    2024-12-13, 06:35 AM
    Currently in Plex i have many parent movie folders
    Movies - French, Movies - Japanese etc etc
    And plex reflects this well.
    I use a folder called, Movies - Music Concerts
    I have a folder called Music Videos
    TV series divided by country
    File Naming - i have my own system that seems to work well in Plex, I wonder if it will work in Jellyfin?
    example -  A Scarred Life (1971) Kizu darake no jinsei [JPN Yakuza D Shigehiro Ozawa 7.2]
    More complex example
     Certain Killer (1967) Aru koroshi ya [JPN Action Crime A Raizô Ichikawa D Kazuo Mori 6.8][1080p BR Rx AVCFLAC.2.0][19.5GB]
    I personally have little interest in the tech details of the file as i view them on a small screen. I do keep some file info but change it so Blueray becomes Br Remux becomes Rx, WED-DL becomes Web as i have more interest in the movie itself and wish to keep the file name shorter so i can add the info that interests myself.
     Usually in my system file folder name is longer and the file name itself is shorter. I remove most . as . i . think . it . is . easier . to . read . without . everywhere.
    My file naming system suits myself well will Jellyfin be able to handle it?
    Please some advice
    Thankyou Chibi
    2024-12-13, 12:27 PM (This post was last modified: 2024-12-13, 12:28 PM by Efficient_Good_5784. Edited 1 time in total.)
    Your movies may work, but tv shows will certainly need to be nested in folders named "season ##" and each episode will also need to have "s##e##".
    You will also need to figure out how to mount each folder as Jellyfin explicitly expects the very first folder to be a show folder with the next subfolders being its seasons. Likewise for movies minus the season folders.
    You also can't mix and match tv shows and movies. Metadata detection is based on the library type the file is stored in.
    Also, if you plan on running Jellyfin over the same media files as Plex at the same time, make sure to disable Jellyfin's ability to store or modify metadata on the media file locations as Jellyfin uses a different structure of files for metadata.
    SelfContained
    2025-09-28, 05:14 PM
    Definitely appreciate this helpful tip!
    "make sure to disable Jellyfin's ability to store or modify metadata on the media file locations"
    Only question now is: where do I find that setting in 10.10.7? lol
    (literally a brand new user here coming from plex, setting up my first folders)
