    Jellyfin Forum Support Troubleshooting Wrong audio track selected by default - Jellyfin for Kodi
    Flashwit
    2024-12-14, 06:12 PM
    I'm basically trying to figure out whether to hunt this down in Kodi, J4K, or Jellyfin itself.
    Jellyfin 10.10.3, latest releases of Kodi Omega and the J4K plugin.
    A test file for this was Downton Abbey (2019) which has Dolby Vision and 3 audio tracks.
    The first audio track (TrueHD + Atmos 7.1) is also set as the default.
    2nd track is AC-3 5.1
    3rd track is AC-3 2 channel commentary track
    If I open it in the web interface the TrueHD track is selected and plays by default.
    If I play it in Kodi using Jellycon the TrueHD track plays by default.
    Yet, if I play it in Kodi using Jellyfin for Kodi, the commentary track plays by default.
    I can change it and click 'set as default' as many times as I want, it will always start the commentary track when I play it with J4K.
    I have extracted some relevant logs. This is logging when I tried with J4K
    https://pastebin.com/XDU1GYxH
    I can see that when it plays on line 28 it's setting AudioStreamIndex to '3' which is the correct index for the TrueHD track.
    I'm not sure how to interpret the stuff after that but the audio stream just seems to die for no reason. It then loads the subtitles and out of nowhere it's loading up the stereo commentary track (ac-3).
    Line 103-104 is where I manually switched it to the TrueHD track which it seems to load with no problem. I don't see any clear issue here.
    For comparison I looked at the log for Jellycon as well.
    https://pastebin.com/uCMYVVbW
    In this case you can see it immediately sees it as TrueHD on line 15 and no problems occur after that.
    I didn't see anything relevant in the Jellyfin server logs.
