Hi, i was wondering if it is possible to use a raspberry 3a + DAC (hifiberry DAC+) just as a client for jellyfin.
My goal–> streaming in flac qualitiy inside my wlan network at home using high quality soundoutput of the hifiberry to my analog HIFI-system. All Controlled by my smartphone.
Do you have any idea how to realise that. It would be great to just be able using Hifiberry/Raspberry 3a as a client without screen or anything.
Via Smartphone jellyfin app i is possible to play via dlna on other devices. If it is possible just to install a jellyfinclient with autpostart i should be able to start/play via smartphone.
An other idea would be streaming from a second smartphone with the jellyfin-app to the raspiclient via usb-connection. But i have no idea with which raspy-software this would otentially work.
Thank you very much.
