Hi all ,
Recently make a change to my movie server from plex to jellyfin , but the problem is with subbtitles
some characters are showing like ?
is there any plugin or setting to fix the problem ?
thank you
Hi all ,
thank you
Hi there
What language are the subtitles in?
the language used in image is romanian
Hi,
I also faced this issue. Is it resolved or will it be fixed in a future update? Do you need any/more detail from my side or the picture from the beginning of this topic is concludent.
All the best.
Hi, I have the same problem, the Romanian diacritics (about 5 of them) are not properly displayed, as shown in the first post here. Can we install anything that can help at the OS level?
Thank you,
ioan
