Hi all,
i am running into issues installing the latest Kodi Syn Queue plugin (6.0.0.0) for Jellyfin (running on Docker/Synology). As soo as i try to install it using the GUI the installation will never end and the logs are filled with the following entry:
[2021-01-12 14:47:19.071 +00:00] [ERR] [12] Emby.Server.Implementations.HttpServer.HttpListenerHost: Error processing request. URL: “http://10.2.0.20:8096/Packages/Installed/Kodi Sync Queue?AssemblyGuid=771e19d6-5385-4caf-b35c-28a0e865cf63&version=6.0.0.0”
MediaBrowser.Common.Extensions.ResourceNotFoundException: Package not found: Kodi Sync Queue
at MediaBrowser.Api.PackageService.Post(InstallPackage request)
Can anybody help me to sort this out ?
Best Regards and thanks in advance
