    Jellyfin Forum Support Troubleshooting Android TV Jellyfin will not display certain PGS Subtitles
    Issues with PGS subtitles with 'forced' flag
    Andokai
    2024-10-29, 07:04 PM
    Hello All,
    I believe this has been since the update to Android tv version 0.17.x, but since then PGS subtitles labeled 'Forced' will only pull up the "unable to load subtitles." These are taken straight from the blu-ray and would be the subtitles that translates songs, and Japanese text into English. I labeled them forced and Default. There is no error when playing the 'Full' subtitle track (namely those with both what the actors are saying and the necessary signage that was translated.) Ive attached the FFMPEG log, which is from playing on my 2012 iMac using the Jellyfin app. This is only not working on the Android TV, which as of recently is running on an Nvidia Shield Pro. (This error was happening on the sony tv that was being used beforehand as well.) It is perfectly possible that I have done something wrong in setting the 'forced' flag. Any help in rectifying or guiding me in the right direction is greatly appreciated.
    .txt   FFMPEG log 10_29 @11-54.txt (Size: 26.65 KB / Downloads: 122)
    Truenas Scale 24.10.2
    Ryzen 5 5600x
    Boot-500gb Samsung 870 EVO
        2x Seagate Ironwolf 8TB
        2x HGST He8 8TB
       all in RaidZ1 array
    2024-10-29, 07:12 PM
    Do you have video transcoding disabled? PGS subs would require they be burned in.
    Andokai
    2024-10-29, 07:24 PM
    No, the Server has transcoding enabled, and does when needed (when video/audio tracks), but it wont even allow me to attempt to transcode to put in this track. I dont even think that it transcodes for the 'Full' track, which is also a PGS sub. I also have Subtitle extraction on the fly enabled. Could it be something as simple as I have the labels wrong? that because its both labeled 'Forced' and 'Default' that its getting confused?
    Ryzen 5 5600x
        2x HGST He8 8TB
       all in RaidZ1 array
    2024-10-29, 07:26 PM
    Shouldn't matter. If you select the track it should burn it in.
    Can you share the main jellyfin log via pastebin?
    Andokai
    2024-10-29, 07:37 PM
    Apologies, my Log was too long, I had to cut it down until it only displays the last 40ish min. Im putting it below
    jellyfin log
    Ryzen 5 5600x
        2x HGST He8 8TB
       all in RaidZ1 array
    2024-10-29, 08:04 PM
    Do you have on-the-fly subtitle extraction enabled or disabled? Dashboard > Playback > Transcoding.
    Or do you have the subtitle extract plugin installed?
    Andokai
    2024-10-29, 08:06 PM (This post was last modified: 2024-10-29, 08:07 PM by Andokai. Edited 1 time in total.)
    (2024-10-29, 08:04 PM)TheDreadPirate Wrote: Do you have on-the-fly subtitle extraction enabled or disabled?  Dashboard > Playback > Transcoding.
    I have on-the-fly enabled, and it was enabled when I ran 0.16.x when it worked (or at least when I believe it did), I do not have the plugin.
    Ryzen 5 5600x
        2x HGST He8 8TB
       all in RaidZ1 array
    Andokai
    2024-10-29, 09:26 PM (This post was last modified: 2024-10-29, 09:39 PM by Andokai. Edited 2 times in total.)
    The only time that selecting a subtitle forces immediate transcoding without dropping the bitrate to very low is enabling a VODSUB. That is for the same type of subtitle track (Only the Song Lyrics and Sign subtitles), I removed the 'Forced' Flag from one, while maintaining the 'Default' Flag, but it still gave me the "Unable to load Subtitle" along with a new error "Encountered Player error, will Re-try" which then goes back to try the subtitle again, with the same error. Idk why it does this behavior, but am willing and happy to be told what I've done wrong, as I've obviously done something lol.
    Edit: I've attached the log of the successful VODSUB transcode, where it automatically did it when selecting the subtitle to play.
    .txt   Log.txt (Size: 27.79 KB / Downloads: 111)
    Edit 2: Even more odd, when trying a different release (Still PGS Subs, and still just taken directly from the blu ray) but from a different company, they work immediately, without the need to transcode at all. Its listed as Direct Play from the Dashboard,
    Ryzen 5 5600x
        2x HGST He8 8TB
       all in RaidZ1 array
    2024-10-29, 10:12 PM
    Do you only have issues with PGS subs with a particular movie/show/episode? Or across the board?
    Andokai
    2024-10-29, 10:19 PM (This post was last modified: 2024-10-29, 10:43 PM by TheDreadPirate. Edited 1 time in total.)
    (2024-10-29, 10:12 PM)TheDreadPirate Wrote: Do you only have issues with PGS subs with a particular movie/show/episode?  Or across the board?
    It seems to only be the Songs and Signs tracks of some Anime releases, generally all {We don't talk about sourcing - TDP}, yet some work. For example "Saga of Tanya the Evil" worked fine, but "Ancient Magus Bride, Spy x Family, Bungo Stray Dogs, Ouran Highschool Host club, The Case Study of Vanitas, Overlord, Fire Force, Black Clover, Assassination Classroom" dont. There probably is more, but those are all the ones I can remember testing and getting the error for sure. IDK why Tanya worked, it was a surprise for me as well.
    Ryzen 5 5600x
        2x HGST He8 8TB
       all in RaidZ1 array
