2025-11-16, 08:45 PM
Hello all,
I'm having a bit of an issue with what I believe to be audio transcoding, I'm not super familiar with Jellyfin, so you will have to bear with me. I have both music and movies downloaded on my devices and find that the audio plays fine (iTunes, MS Media player, VLC, etc) however as soon as I dump it onto Jellyfin no matter the device the audio and even to some extent the bass boost is insainely decreased forcing me to crank the volume on my device to MAX volume in some cases.
Is there anything in Jellyfin I can do in to increase the general volume so I don't have to crank the volume every time, or am I pretty much screwed? At this point it might be better to just download the actual file instead of going through a headache just to have normal audio quality.
thanks
thanks
