    Jellyfin Forum Support Troubleshooting Audio transcoding issue with HE-AAC 5.1 on Android TV with AV receiver โ€“ causes slow
    Armand
    Country:France
    2025-04-23, 02:17 PM
    Hello Jellyfin team,
    Iโ€™m encountering a consistent issue with audio playback when using Jellyfin on Android TV, specifically when an AV receiver is involved.
    ๐Ÿงฉ Setup:
    • Server: Jellyfin running in Docker on a hosted seedbox (HostingByDesign), using the official Jellyfin Docker image
    • FFmpeg: The image uses
      /usr/lib/jellyfin-ffmpeg/ffmpeg
      , which appears non-functional in my environment (transcoding fails silently)
    • Client device: SFR Android TV box
    • Audio output:
      • โœ… Works perfectly on a regular stereo TV (no receiver)
      • โŒ Fails when connected to a Yamaha AV Receiver (HTR-6240) via HDMI
    ๐ŸŽง Problem Description:
    When playing a video with HE-AAC 5.1 audio, everything works fine on a stereo TV (I assume it's direct-play). However, on a TV connected to a 5.1 AV receiver, playback slows down dramatically and the sound becomes completely distorted โ€” as if the audio isn't being transcoded properly.
    I suspect the following:
    • The AV receiver cannot handle HE-AAC 5.1 directly
    • The client requests transcoding from the server
    • The server is unable to transcode due to FFmpeg issues (invalid path or missing binaries)
    • As a result, the stream becomes unplayable on that setup
    ๐Ÿ” Additional Notes:
    • FFmpeg path in the Jellyfin admin interface is set to
      and not editable in the Docker image.
    • System-wide FFmpeg exists at
      /usr/bin/ffmpeg
      , but I cannot configure Jellyfin to use it due to Docker and permission restrictions.
    • I'm unable to access Docker directly (limited hosting environment), so I cannot modify the container or mount volumes to override FFmpeg.
    ๐Ÿ™ Request:
    Is this a known issue with HE-AAC 5.1 transcoding on Android TV when used with an AV receiver?
    Can the Docker image:
    • Be made more flexible regarding FFmpeg path?
    • Include a fallback or compatibility fix for transcoding HE-AAC audio properly in such scenarios?
    Or alternatively: is there a recommended workaround (short of re-encoding every file manually)?
    Thank you very much for your support and for this great project ๐Ÿ™Œ
    Let me know if I can provide logs or run any tests.
    Best regards
    2025-04-23, 04:22 PM
    Post the FFmpeg logs of you attempt to play an item with 5.1 AAC audio.
    Armand
    Country:France
    2025-04-23, 05:27 PM (This post was last modified: 2025-04-23, 05:29 PM by Armand.)
    when I force on my android tv decoder, in the jellyfin client the option "audio output: submix in stereo", the film plays well with the sound without slowness, and I find the ffmpeg log file attached. on the other hand when I configure the audio output in "Direct", the film plays frame by frame with distorted sound, and in this case I do not have a log file.
    {"Protocol":0,"Id":"17858fbe2d5b1f5d940d13048eeb9055","Path":"/data/torrents/films/Godzilla.Minus.One.2023.MULTI.VFF.1080p.10bit.WEBRip.6CH.x265.HEVC-SERQPH.mkv","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"mkv","Size":2427999528,"Name":"Godzilla.Minus.One.2023.MULTI.VFF.1080p.10bit.WEBRip.6CH.x265.HEVC-SERQPH","IsRemote":false,"ETag":"8cf00ca1796ed400599309e2054b68fe","RunTimeTicks":75837520000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"UseMostCompatibleTranscodingProfile":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"hevc","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"1080p HEVC SDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":2561264,"BitDepth":10,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":808,"Width":1920,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"ReferenceFrameRate":23.976025,"Profile":"Main 10","Type":1,"AspectRatio":"2.40:1","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"aac","CodecTag":null,"Language":"fre","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"VFF","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Par d\u00E9faut","LocalizedForced":null,"LocalizedExternal":"Externe","LocalizedHearingImpaired":null,"DisplayTitle":"VFF - Fre - HE-AAC - 5.1 - Par d\u00E9faut","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"5.1","BitRate":188079,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":"HE-AAC","Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"aac","CodecTag":null,"Language":"jpn","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"VO","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Par d\u00E9faut","LocalizedForced":null,"LocalizedExternal":"Externe","LocalizedHearingImpaired":null,"DisplayTitle":"VO - Japanese - HE-AAC - 5.1","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"5.1","BitRate":190582,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":"HE-AAC","Type":0,"AspectRatio":null,"Index":2,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"fre","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"FORCED","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Non d\u00E9fini","LocalizedDefault":"Par d\u00E9faut","LocalizedForced":"Forc\u00E9","LocalizedExternal":"Externe","LocalizedHearingImpaired":"Malentendants","DisplayTitle":"FORCED - Fre - Par d\u00E9faut - Forc\u00E9 - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":true,"IsForced":true,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":3,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"fre","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"FULL","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Non d\u00E9fini","LocalizedDefault":"Par d\u00E9faut","LocalizedForced":"Forc\u00E9","LocalizedExternal":"Externe","LocalizedHearingImpaired":"Malentendants","DisplayTitle":"FULL - Fre - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":4,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"Anglais SDH","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Non d\u00E9fini","LocalizedDefault":"Par d\u00E9faut","LocalizedForced":"Forc\u00E9","LocalizedExternal":"Externe","LocalizedHearingImpaired":"Malentendants","DisplayTitle":"Anglais SDH - English - Malentendants - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":true,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":5,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"jpn","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"Japonais SDH","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Non d\u00E9fini","LocalizedDefault":"Par d\u00E9faut","LocalizedForced":"Forc\u00E9","LocalizedExternal":"Externe","LocalizedHearingImpaired":"Malentendants","DisplayTitle":"Japonais SDH - Japanese - Malentendants - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":true,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":6,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":2939925,"FallbackMaxStreamingBitrate":null,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null,"HasSegments":false}
    /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -ss 00:41:36.702 -fflags +genpts -i file:"/data/torrents/films/Godzilla.Minus.One.2023.MULTI.VFF.1080p.10bit.WEBRip.6CH.x265.HEVC-SERQPH.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -tag:v:0 hvc1 -bsf:v hevc_mp4toannexb -start_at_zero -codec:a:0 libfdk_aac -ac 2 -ab 188079 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 6 -hls_segment_type mpegts -start_number 416 -hls_segment_filename "/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f.m3u8"
    ffmpeg version 7.0.2-Jellyfin Copyright © 2000-2024 the FFmpeg developers
    libavutil 59. 8.100 / 59. 8.100
    libavcodec 61. 3.100 / 61. 3.100
    libavformat 61. 1.100 / 61. 1.100
    libavdevice 61. 1.100 / 61. 1.100
    libavfilter 10. 1.100 / 10. 1.100
    libswscale 8. 1.100 / 8. 1.100
    libswresample 5. 1.100 / 5. 1.100
    libpostproc 58. 1.100 / 58. 1.100
    Input #0, matroska,webm, from 'fileConfused-facedata/torrents/films/Godzilla.Minus.One.2023.MULTI.VFF.1080p.10bit.WEBRip.6CH.x265.HEVC-SERQPH.mkv':
    Metadata:
    title : Godzilla Minus One (2023) par SERQPH
    encoder : libebml v1.4.5 + libmatroska v1.7.1
    creation_time : 2024-06-01T09:01:57.000000Z
    MOVIE/ENCODER : fdkaac 1.0.0, libfdk-aac 4.0.0, VBR mode 3
    Duration: 02:06:23.75, start: 0.000000, bitrate: 2561 kb/s
    Chapters:
    Chapter #0:0: start 0.000000, end 801.509000
    Metadata:
    title : Chapter 01
    Chapter #0:1: start 801.509000, end 1207.665000
    Metadata:
    title : Chapter 02
    Chapter #0:2: start 1207.665000, end 1831.580000
    Metadata:
    title : Chapter 03
    Chapter #0:3: start 1831.580000, end 2693.566000
    Metadata:
    title : Chapter 04
    Chapter #0:4: start 2693.566000, end 3148.020000
    Metadata:
    title : Chapter 05
    Chapter #0:5: start 3148.020000, end 3942.272000
    Metadata:
    title : Chapter 06
    Chapter #0:6: start 3942.272000, end 4492.279000
    Metadata:
    title : Chapter 07
    Chapter #0:7: start 4492.279000, end 4679.717000
    Metadata:
    title : Chapter 08
    Chapter #0:8: start 4679.717000, end 5142.012000
    Metadata:
    title : Chapter 09
    Chapter #0:9: start 5142.012000, end 5781.025000
    Metadata:
    title : Chapter 10
    Chapter #0:10: start 5781.025000, end 7138.798000
    Metadata:
    title : Chapter 11
    Chapter #0:11: start 7138.798000, end 7583.752000
    Metadata:
    title : Chapter 12
    Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1920x808, SAR 1:1 DAR 240:101, 23.98 fps, 23.98 tbr, 1k tbn (default)
    Metadata:
    BPS : 2210757
    DURATION : 02:04:38.179000000
    NUMBER_OF_FRAMES: 179297
    NUMBER_OF_BYTES : 2066555331
    _STATISTICS_WRITING_APP: mkvmerge v83.0 ('Circle Of Friends') 64-bit
    _STATISTICS_WRITING_DATE_UTC: 2024-06-01 09:01:57
    Stream #0:1(fre): Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)
    Metadata:
    title : VFF
    BPS : 188079
    DURATION : 02:06:23.745000000
    NUMBER_OF_FRAMES: 177744
    NUMBER_OF_BYTES : 178293617
    Stream #0:2(jpn): Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp
    Metadata:
    title : VO
    BPS : 190582
    DURATION : 02:06:23.361000000
    NUMBER_OF_FRAMES: 177735
    NUMBER_OF_BYTES : 180656893
    Stream #0:3(fre): Subtitle: subrip (srt) (default) (forced)
    Metadata:
    title : FORCED
    BPS : 1
    DURATION : 01:35:36.022000000
    NUMBER_OF_FRAMES: 26
    NUMBER_OF_BYTES : 746
    Stream #0:4(fre): Subtitle: subrip (srt)
    Metadata:
    title : FULL
    BPS : 39
    DURATION : 02:04:25.082000000
    NUMBER_OF_FRAMES: 1084
    NUMBER_OF_BYTES : 36554
    Stream #0:5(eng): Subtitle: subrip (srt) (hearing impaired)
    Metadata:
    title : Anglais SDH
    BPS : 60
    DURATION : 02:04:03.102000000
    NUMBER_OF_FRAMES: 1769
    NUMBER_OF_BYTES : 56328
    Stream #0:6(jpn): Subtitle: subrip (srt) (hearing impaired)
    Metadata:
    title : Japonais SDH
    BPS : 60
    DURATION : 02:04:01.685000000
    NUMBER_OF_FRAMES: 1746
    NUMBER_OF_BYTES : 56680
    Stream mapping:
    Stream #0:0 -> #0:0 (copy)
    Stream #0:1 -> #0:1 (aac (native) -> aac (libfdk_aac))
    Output #0, hls, to '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f.m3u8':
    Metadata:
    encoder : Lavf61.1.100
    Stream #0:0: Video: hevc (Main 10) (hvc1 / 0x3163766Nerd-face, yuv420p10le(tv), 1920x808 [SAR 1:1 DAR 240:101], q=2-31, 23.98 fps, 23.98 tbr, 90k tbn (default)
    Stream #0:1: Audio: aac, 48000 Hz, stereo, s16, 188 kb/s (default)
    Metadata:
    encoder : Lavc61.3.100 libfdk_aac
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f416.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f417.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f418.ts' for writing
    size=N/A time=00:00:00.00 bitrate=N/A speed= 0x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f419.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f420.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f421.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f422.ts' for writing
    size=N/A time=00:00:23.57 bitrate=N/A speed=23.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f423.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f424.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f425.ts' for writing
    size=N/A time=00:00:42.64 bitrate=N/A speed=28.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f426.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f427.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f428.ts' for writing
    size=N/A time=00:01:00.71 bitrate=N/A speed=30.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f429.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f430.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f431.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f432.ts' for writing
    size=N/A time=00:01:25.58 bitrate=N/A speed=34.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f433.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f434.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f435.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f436.ts' for writing
    size=N/A time=00:01:49.61 bitrate=N/A speed=36.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f437.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f438.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f439.ts' for writing
    size=N/A time=00:02:13.44 bitrate=N/A speed=38.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f440.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f441.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f442.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f443.ts' for writing
    size=N/A time=00:02:37.84 bitrate=N/A speed=39.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f444.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f445.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f446.ts' for writing
    size=N/A time=00:03:00.20 bitrate=N/A speed= 40x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f447.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f448.ts' for writing
    size=N/A time=00:03:17.24 bitrate=N/A speed=39.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f449.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f450.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f451.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f452.ts' for writing
    size=N/A time=00:03:38.62 bitrate=N/A speed=39.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f453.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f454.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f455.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f456.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f457.ts' for writing
    size=N/A time=00:04:04.43 bitrate=N/A speed=40.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f458.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f459.ts' for writing
    size=N/A time=00:04:29.99 bitrate=N/A speed=41.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f460.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f461.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f462.ts' for writing
    size=N/A time=00:04:55.23 bitrate=N/A speed=42.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f463.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f464.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f465.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f466.ts' for writing
    size=N/A time=00:05:21.94 bitrate=N/A speed=42.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f467.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f468.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f469.ts' for writing
    size=N/A time=00:05:50.63 bitrate=N/A speed=43.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f470.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f471.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f472.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f473.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f474.ts' for writing
    size=N/A time=00:06:18.66 bitrate=N/A speed=44.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f475.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f476.ts' for writing
    size=N/A time=00:06:46.07 bitrate=N/A speed=45.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f477.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f478.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f479.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f480.ts' for writing
    size=N/A time=00:07:12.34 bitrate=N/A speed=45.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f481.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f482.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f483.ts' for writing
    size=N/A time=00:07:39.41 bitrate=N/A speed=45.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f484.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f485.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f486.ts' for writing
    size=N/A time=00:08:04.97 bitrate=N/A speed=46.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f487.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f488.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f489.ts' for writing
    size=N/A time=00:08:33.83 bitrate=N/A speed=46.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f490.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f491.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f492.ts' for writing
    size=N/A time=00:09:02.59 bitrate=N/A speed=47.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f493.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f494.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f495.ts' for writing
    size=N/A time=00:09:31.02 bitrate=N/A speed=47.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f496.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f497.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f498.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f499.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f500.ts' for writing
    size=N/A time=00:09:59.72 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f501.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f502.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f503.ts' for writing
    size=N/A time=00:10:25.51 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f504.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f505.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f506.ts' for writing
    size=N/A time=00:10:51.51 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f507.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f508.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f509.ts' for writing
    size=N/A time=00:11:14.83 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f510.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f511.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f512.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f513.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f514.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f515.ts' for writing
    size=N/A time=00:11:38.94 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f516.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f517.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f518.ts' for writing
    size=N/A time=00:12:02.92 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f519.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f520.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f521.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f522.ts' for writing
    size=N/A time=00:12:26.28 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f523.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f524.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f525.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f526.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f527.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f528.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f529.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f530.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f531.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f532.ts' for writing
    size=N/A time=00:12:49.21 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f533.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f534.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f535.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f536.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f537.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f538.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f539.ts' for writing
    size=N/A time=00:13:12.74 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f540.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f541.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f542.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f543.ts' for writing
    size=N/A time=00:13:36.10 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f544.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f545.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f546.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f547.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f548.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f549.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f550.ts' for writing
    size=N/A time=00:13:59.21 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f551.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f552.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f553.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f554.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f555.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f556.ts' for writing
    size=N/A time=00:14:23.53 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f557.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f558.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f559.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f560.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f561.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f562.ts' for writing
    size=N/A time=00:14:47.32 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f563.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f564.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f565.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f566.ts' for writing
    size=N/A time=00:15:10.65 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f567.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f568.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f569.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f570.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f571.ts' for writing
    size=N/A time=00:15:35.31 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f572.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f573.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f574.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f575.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f576.ts' for writing
    size=N/A time=00:15:56.69 bitrate=N/A speed=47.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f577.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f578.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f579.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f580.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f581.ts' for writing
    size=N/A time=00:16:19.77 bitrate=N/A speed=47.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f582.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f583.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f584.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f585.ts' for writing
    size=N/A time=00:16:44.07 bitrate=N/A speed=47.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f586.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f587.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f588.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f589.ts' for writing
    size=N/A time=00:17:06.92 bitrate=N/A speed=47.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f590.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f591.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f592.ts' for writing
    size=N/A time=00:17:22.00 bitrate=N/A speed=47.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f593.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f594.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f595.ts' for writing
    size=N/A time=00:17:42.25 bitrate=N/A speed=47.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f596.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f597.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f598.ts' for writing
    size=N/A time=00:18:02.92 bitrate=N/A speed=47.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f599.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f600.ts' for writing
    size=N/A time=00:18:23.55 bitrate=N/A speed=46.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f601.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f602.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f603.ts' for writing
    size=N/A time=00:18:49.68 bitrate=N/A speed=47.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f604.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f605.ts' for writing
    size=N/A time=00:19:14.79 bitrate=N/A speed=47.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f606.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f607.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f608.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f609.ts' for writing
    size=N/A time=00:19:37.85 bitrate=N/A speed=47.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f610.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f611.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f612.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f613.ts' for writing
    size=N/A time=00:20:02.36 bitrate=N/A speed=47.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f614.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f615.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f616.ts' for writing
    size=N/A time=00:20:25.72 bitrate=N/A speed=47.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f617.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f618.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f619.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f620.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f621.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f622.ts' for writing
    size=N/A time=00:20:48.78 bitrate=N/A speed=47.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f623.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f624.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f625.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f626.ts' for writing
    size=N/A time=00:21:14.17 bitrate=N/A speed=47.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f627.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f628.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f629.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f630.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f631.ts' for writing
    size=N/A time=00:21:43.36 bitrate=N/A speed=47.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f632.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f633.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f634.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f635.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f636.ts' for writing
    size=N/A time=00:22:11.39 bitrate=N/A speed=47.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f637.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f638.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f639.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f640.ts' for writing
    size=N/A time=00:22:45.41 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f641.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f642.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f643.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f644.ts' for writing
    size=N/A time=00:23:18.67 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f645.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f646.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f647.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f648.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f649.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f650.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f651.ts' for writing
    size=N/A time=00:23:47.90 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f652.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f653.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f654.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f655.ts' for writing
    size=N/A time=00:24:14.35 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f656.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f657.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f658.ts' for writing
    size=N/A time=00:24:39.99 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f659.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f660.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f661.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f662.ts' for writing
    size=N/A time=00:25:06.13 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f663.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f664.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f665.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f666.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f667.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f668.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f669.ts' for writing
    Armand
    Country:France
    size=N/A time=00:25:33.61 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f670.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f671.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f672.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f673.ts' for writing
    size=N/A time=00:25:59.67 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f674.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f675.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f676.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f677.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f678.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f679.ts' for writing
    size=N/A time=00:26:28.33 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f680.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f681.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f682.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f683.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f684.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f685.ts' for writing
    size=N/A time=00:26:56.70 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f686.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f687.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f688.ts' for writing
    size=N/A time=00:27:24.73 bitrate=N/A speed=49.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f689.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f690.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f691.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f692.ts' for writing
    size=N/A time=00:27:52.87 bitrate=N/A speed=49.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f693.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f694.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f695.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f696.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f697.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f698.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f699.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f700.ts' for writing
    size=N/A time=00:28:21.16 bitrate=N/A speed=49.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f701.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f702.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f703.ts' for writing
    size=N/A time=00:28:49.17 bitrate=N/A speed=49.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f704.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f705.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f706.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f707.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f708.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f709.ts' for writing
    size=N/A time=00:29:16.50 bitrate=N/A speed=49.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f710.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f711.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f712.ts' for writing
    size=N/A time=00:29:25.20 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f713.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f714.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f715.ts' for writing
    size=N/A time=00:29:46.19 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f716.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f717.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f718.ts' for writing
    size=N/A time=00:30:09.34 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f719.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f720.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f721.ts' for writing
    size=N/A time=00:30:33.68 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f722.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f723.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f724.ts' for writing
    size=N/A time=00:30:57.87 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f725.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f726.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f727.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f728.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f729.ts' for writing
    size=N/A time=00:31:23.34 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f730.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f731.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f732.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f733.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f734.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f735.ts' for writing
    size=N/A time=00:31:50.95 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f736.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f737.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f738.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f739.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f740.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f741.ts' for writing
    size=N/A time=00:32:17.21 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f742.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f743.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f744.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f745.ts' for writing
    size=N/A time=00:32:38.33 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f746.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f747.ts' for writing
    size=N/A time=00:33:01.26 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f748.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f749.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f750.ts' for writing
    size=N/A time=00:33:27.89 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f751.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f752.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f753.ts' for writing
    size=N/A time=00:33:54.30 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f754.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f755.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f756.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f757.ts' for writing
    size=N/A time=00:34:17.53 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f758.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f759.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f760.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f761.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f762.ts' for writing
    size=N/A time=00:34:42.45 bitrate=N/A speed= 49x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f763.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f764.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f765.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f766.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f767.ts' for writing
    size=N/A time=00:35:03.27 bitrate=N/A speed=48.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f768.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f769.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f770.ts' for writing
    size=N/A time=00:35:20.51 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f771.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f772.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f773.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f774.ts' for writing
    size=N/A time=00:35:47.86 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f775.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f776.ts' for writing
    size=N/A time=00:36:05.93 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f777.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f778.ts' for writing
    size=N/A time=00:36:27.90 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f779.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f780.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f781.ts' for writing
    size=N/A time=00:36:48.44 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f782.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f783.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f784.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f785.ts' for writing
    size=N/A time=00:37:08.65 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f786.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f787.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f788.ts' for writing
    size=N/A time=00:37:29.40 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f789.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f790.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f791.ts' for writing
    size=N/A time=00:37:49.76 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f792.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f793.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f794.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f795.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f796.ts' for writing
    size=N/A time=00:38:14.61 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f797.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f798.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f799.ts' for writing
    size=N/A time=00:38:35.00 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f800.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f801.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f802.ts' for writing
    size=N/A time=00:38:51.68 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f803.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f804.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f805.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f806.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f807.ts' for writing
    size=N/A time=00:39:13.10 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f808.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f809.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f810.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f811.ts' for writing
    size=N/A time=00:39:40.09 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f812.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f813.ts' for writing
    size=N/A time=00:40:01.72 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f814.ts' for writing
    size=N/A time=00:40:17.30 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f815.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f816.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f817.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f818.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f819.ts' for writing
    size=N/A time=00:40:40.55 bitrate=N/A speed=47.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f820.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f821.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f822.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f823.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f824.ts' for writing
    size=N/A time=00:41:05.68 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f825.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f826.ts' for writing
    size=N/A time=00:41:27.40 bitrate=N/A speed=47.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f827.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f828.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f829.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f830.ts' for writing
    size=N/A time=00:41:52.51 bitrate=N/A speed=47.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f831.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f832.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f833.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f834.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f835.ts' for writing
    size=N/A time=00:42:16.98 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f836.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f837.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f838.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f839.ts' for writing
    size=N/A time=00:42:41.34 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f840.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f841.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f842.ts' for writing
    size=N/A time=00:43:04.93 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f843.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f844.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f845.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f846.ts' for writing
    size=N/A time=00:43:29.40 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f847.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f848.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f849.ts' for writing
    size=N/A time=00:43:54.02 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f850.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f851.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f852.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f853.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f854.ts' for writing
    size=N/A time=00:44:19.64 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f855.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f856.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f857.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f858.ts' for writing
    size=N/A time=00:44:45.01 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f859.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f860.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f861.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f862.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f863.ts' for writing
    size=N/A time=00:45:09.75 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f864.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f865.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f866.ts' for writing
    size=N/A time=00:45:34.40 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f867.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f868.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f869.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f870.ts' for writing
    size=N/A time=00:46:01.19 bitrate=N/A speed= 48x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f871.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f872.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f873.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f874.ts' for writing
    size=N/A time=00:46:28.67 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f875.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f876.ts' for writing
    size=N/A time=00:46:55.57 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f877.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f878.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f879.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f880.ts' for writing
    size=N/A time=00:47:22.17 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f881.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f882.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f883.ts' for writing
    size=N/A time=00:47:49.84 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f884.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f885.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f886.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f887.ts' for writing
    size=N/A time=00:48:17.89 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f888.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f889.ts' for writing
    size=N/A time=00:48:45.50 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f890.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f891.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f892.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f893.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f894.ts' for writing
    size=N/A time=00:49:13.57 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f895.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f896.ts' for writing
    size=N/A time=00:49:35.99 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f897.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f898.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f899.ts' for writing
    size=N/A time=00:50:01.17 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f900.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f901.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f902.ts' for writing
    size=N/A time=00:50:27.56 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f903.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f904.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f905.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f906.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f907.ts' for writing
    size=N/A time=00:50:54.05 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f908.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f909.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f910.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f911.ts' for writing
    size=N/A time=00:51:20.42 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f912.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f913.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f914.ts' for writing
    size=N/A time=00:51:47.60 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f915.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f916.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f917.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f918.ts' for writing
    size=N/A time=00:52:16.06 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f919.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f920.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f921.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f922.ts' for writing
    size=N/A time=00:52:43.43 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f923.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f924.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f925.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f926.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f927.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f928.ts' for writing
    size=N/A time=00:53:10.67 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f929.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f930.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f931.ts' for writing
    size=N/A time=00:53:36.49 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f932.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f933.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f934.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f935.ts' for writing
    size=N/A time=00:54:04.62 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f936.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f937.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f938.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f939.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f940.ts' for writing
    size=N/A time=00:54:31.08 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f941.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f942.ts' for writing
    size=N/A time=00:54:56.85 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f943.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f944.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f945.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f946.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f947.ts' for writing
    size=N/A time=00:55:21.51 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f948.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f949.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f950.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f951.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f952.ts' for writing
    size=N/A time=00:55:44.64 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f953.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f954.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f955.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f956.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f957.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f958.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f959.ts' for writing
    size=N/A time=00:56:10.41 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f960.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f961.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f962.ts' for writing
    size=N/A time=00:56:31.46 bitrate=N/A speed=48.8x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f963.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f964.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f965.ts' for writing
    size=N/A time=00:56:50.13 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f966.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f967.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f968.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f969.ts' for writing
    size=N/A time=00:57:13.04 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f970.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f971.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f972.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f973.ts' for writing
    size=N/A time=00:57:36.64 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f974.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f975.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f976.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f977.ts' for writing
    size=N/A time=00:58:00.44 bitrate=N/A speed=48.7x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f978.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f979.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f980.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f981.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f982.ts' for writing
    size=N/A time=00:58:21.97 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f983.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f984.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f985.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f986.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f987.ts' for writing
    size=N/A time=00:58:47.46 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f988.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f989.ts' for writing
    size=N/A time=00:59:10.63 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f990.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f991.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f992.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f993.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f994.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f995.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f996.ts' for writing
    size=N/A time=00:59:34.54 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f997.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f998.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f999.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1000.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1001.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1002.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1003.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1004.ts' for writing
    size=N/A time=00:59:58.89 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1005.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1006.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1007.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1008.ts' for writing
    size=N/A time=01:00:21.52 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1009.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1010.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1011.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1012.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1013.ts' for writing
    size=N/A time=01:00:42.85 bitrate=N/A speed=48.6x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1014.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1015.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1016.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1017.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1018.ts' for writing
    size=N/A time=01:01:04.98 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1019.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1020.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1021.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1022.ts' for writing
    size=N/A time=01:01:30.06 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1023.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1024.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1025.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1026.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1027.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1028.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1029.ts' for writing
    size=N/A time=01:01:53.83 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1030.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1031.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1032.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1033.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1034.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1035.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1036.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1037.ts' for writing
    size=N/A time=01:02:14.69 bitrate=N/A speed=48.5x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1038.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1039.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1040.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1041.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1042.ts' for writing
    size=N/A time=01:02:33.25 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1043.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1044.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1045.ts' for writing
    size=N/A time=01:02:48.42 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1046.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1047.ts' for writing
    size=N/A time=01:03:08.94 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1048.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1049.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1050.ts' for writing
    size=N/A time=01:03:30.00 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1051.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1052.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1053.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1054.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1055.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1056.ts' for writing
    size=N/A time=01:03:52.72 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1057.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1058.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1059.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1060.ts' for writing
    size=N/A time=01:04:11.41 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1061.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1062.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1063.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1064.ts' for writing
    size=N/A time=01:04:36.35 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1065.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1066.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1067.ts' for writing
    size=N/A time=01:04:59.17 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1068.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1069.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1070.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1071.ts' for writing
    size=N/A time=01:05:23.69 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1072.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1073.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1074.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1075.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1076.ts' for writing
    size=N/A time=01:05:45.30 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1077.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1078.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1079.ts' for writing
    size=N/A time=01:06:09.23 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1080.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1081.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1082.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1083.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1084.ts' for writing
    size=N/A time=01:06:32.76 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1085.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1086.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1087.ts' for writing
    size=N/A time=01:06:55.48 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1088.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1089.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1090.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1091.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1092.ts' for writing
    size=N/A time=01:07:19.57 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1093.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1094.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1095.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1096.ts' for writing
    size=N/A time=01:07:43.74 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1097.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1098.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1099.ts' for writing
    size=N/A time=01:08:07.80 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1100.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1101.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1102.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1103.ts' for writing
    size=N/A time=01:08:31.42 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1104.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1105.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1106.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1107.ts' for writing
    size=N/A time=01:08:57.77 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1108.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1109.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1110.ts' for writing
    size=N/A time=01:09:24.43 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1111.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1112.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1113.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1114.ts' for writing
    size=N/A time=01:09:47.28 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1115.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1116.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1117.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1118.ts' for writing
    size=N/A time=01:10:13.61 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1119.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1120.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1121.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1122.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1123.ts' for writing
    size=N/A time=01:10:41.40 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1124.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1125.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1126.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1127.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1128.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1129.ts' for writing
    size=N/A time=01:11:08.33 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1130.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1131.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1132.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1133.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1134.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1135.ts' for writing
    size=N/A time=01:11:41.48 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1136.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1137.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1138.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1139.ts' for writing
    size=N/A time=01:12:06.03 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1140.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1141.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1142.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1143.ts' for writing
    size=N/A time=01:12:31.33 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1144.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1145.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1146.ts' for writing
    size=N/A time=01:12:57.04 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1147.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1148.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1149.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1150.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1151.ts' for writing
    size=N/A time=01:13:21.34 bitrate=N/A speed=48.4x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1152.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1153.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1154.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1155.ts' for writing
    size=N/A time=01:13:40.24 bitrate=N/A speed=48.3x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1156.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1157.ts' for writing
    size=N/A time=01:13:57.39 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1158.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1159.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1160.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1161.ts' for writing
    size=N/A time=01:14:19.28 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1162.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1163.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1164.ts' for writing
    size=N/A time=01:14:41.81 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1165.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1166.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1167.ts' for writing
    size=N/A time=01:15:05.13 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1168.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1169.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1170.ts' for writing
    size=N/A time=01:15:29.45 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1171.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1172.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1173.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1174.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1175.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1176.ts' for writing
    size=N/A time=01:15:53.17 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1177.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1178.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1179.ts' for writing
    size=N/A time=01:16:17.06 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1180.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1181.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1182.ts' for writing
    size=N/A time=01:16:38.99 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1183.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1184.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1185.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1186.ts' for writing
    size=N/A time=01:17:04.76 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1187.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1188.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1189.ts' for writing
    size=N/A time=01:17:29.49 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1190.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1191.ts' for writing
    size=N/A time=01:17:55.92 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1192.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1193.ts' for writing
    size=N/A time=01:18:08.81 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1194.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1195.ts' for writing
    size=N/A time=01:18:32.51 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1196.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1197.ts' for writing
    size=N/A time=01:18:55.91 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1198.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1199.ts' for writing
    size=N/A time=01:19:19.01 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1200.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1201.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1202.ts' for writing
    size=N/A time=01:19:43.03 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1203.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1204.ts' for writing
    size=N/A time=01:20:08.95 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1205.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1206.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1207.ts' for writing
    size=N/A time=01:20:34.55 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1208.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1209.ts' for writing
    size=N/A time=01:21:01.18 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1210.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1211.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1212.ts' for writing
    size=N/A time=01:21:27.78 bitrate=N/A speed=48.1x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1213.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1214.ts' for writing
    size=N/A time=01:21:53.85 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1215.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1216.ts' for writing
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1217.ts' for writing
    size=N/A time=01:22:21.16 bitrate=N/A speed=48.2x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1218.ts' for writing
    size=N/A time=01:22:38.26 bitrate=N/A speed=48.1x
    size=N/A time=01:22:38.26 bitrate=N/A speed=47.9x
    [hls @ 0x5574d8072dc0] Opening '/cache/transcodes/ee01ee5d2ba2b332289ace9634e37a8f1219.ts' for writing
    [out#0/hls @ 0x5574d808f340] video:1213379KiB audio:116794KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: unknown
    size=N/A time=01:22:38.26 bitrate=N/A speed=47.8x
    Armand
    Country:France
    2025-04-23, 05:34 PM
    Why is there a problem with 5.1? Is it possible to force a true transcoding to AC3 5.1, for example, when the movie's audio format isn't well handled by the amplifier (HE-AAC 5.1)?
    Because today I can't take advantage of my 5.1 setup; I have to watch my movies in stereo, unless they're encoded in AC3 from the start...
    Gilles990
    2025-05-23, 07:53 AM
    Same issue for me, I don't know why but AAC 5.1 is not working in 5.1 in Jellyfin but in 2.0.
    Home ยท Team ยท Help ยท Contact
    ยฉ Designed by D&D - Powered by MyBB
