    Jellyfin Forum Support Troubleshooting Auto generated collage images for Home screen buttons
    kagetsu
    2025-04-09, 09:20 AM
    Anyone know the schedule in which button images are generated and rotated during scan libraries? Mine hasn't updated for 2 weeks now and I do regular scan library scheduled once a day. Only time it seems to trigger is when I manually delete the image on the button and do a manual scan.
    2025-04-09, 01:24 PM
    It rotates images once a week. I'm not aware of a way to set a specific time or day of the week.
    If you've manually set a library image, the image rotation will stop as it is assumed you do not want the server to override your manually set image.
    If you have not manually set a library image, could you share your jellyfin logs via privatebin.net?
    kagetsu
    2025-04-10, 08:06 AM
    Hey Dread! Thank you for always answering. I will wait until Sunday to try again. No I didn't set a image and I'm fully aware if you do set an image it won't override it. Just felt like it would do the collage more often in the past.
