    Jellyfin Forum Support Troubleshooting Codec problems on FireStick TV? Freezing every 5 seconds.
    naopodeser
    2023-11-18, 11:17 PM
    So much problems when I play some videos on FireStick TV. Freezing every 5 seconds. Some shows and movies, work fine.
    First, I had problems on a Samsung TV (Tizen System) run Jellyfin, so I bought a FireStick 4k (I use 1080p) to solve it. The problem, aparently, was codecs. Well, the problem continues.
    Here is Jellyfin's log using FireStick: https://pastebin.com/A9ZmtECz
    I can't transcode from my server, low CPU, low memory, impossible.
    I tryed before transcode with Unmaniac (like Tdarr), but doesn't work. Too much time spend to 1%. And I don't know if this will work. I don't understand which codec is the problem. Which codec is correct to play on Fire Stick?
    On my PC and iPhone, everything work fine.
    Any ideas?
    2023-11-18, 11:38 PM
    Can you share the main jellyfin log? It contains the reason the video was transcoded. The codec is H264, level 41. Pretty pedestrian. So I suspect the Fire TV is transcoding due to "ContainerBitrateExceeded". This is a bug in the Android TV app where the "auto" max bit rate settings is too low. Try manually setting the max bit rate setting in Android TV to 120Mbps.
    tmsrxzar
    2023-11-18, 11:40 PM
    +1
    also check that "Downmix to stereo" is not enabled
    naopodeser
    2023-11-19, 12:19 AM
    (2023-11-18, 11:38 PM)TheDreadPirate Wrote: Can you share the main jellyfin log?  It contains the reason the video was transcoded.  The codec is H264, level 41.  Pretty pedestrian.  So I suspect the Fire TV is transcoding due to "ContainerBitrateExceeded".  This is a bug in the Android TV app where the "auto" max bit rate settings is too low.  Try manually setting the max bit rate setting in Android TV to 120Mbps.
    Main Jellyfin Log: https://pastebin.com/Knervebw
    I try with 120mbps limit, same problem. This is the transcode log: https://pastebin.com/7duCQUMT
    (2023-11-18, 11:40 PM)tmsrxzar Wrote: also check that "Downmix to stereo" is not enabled
    I change to Direct, nothing become better. My server turn down, I think is because this.
    Should I activate the hardware aceleration? If yes, which options I use?
    My setup is a J1800 CPU, 4gb ram, on docker run into OMV Server.
    tmsrxzar
    2023-11-19, 12:32 AM
    log shows the same thing so no doubt it had the same problem
    Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
    Stream #0:1 -> #0:1 (ac3 (native) -> aac (libfdk_aac))
    means it's being transcoded, if direct playing it would say (copy)
    since it's going h264->h264 then video codec shouldn't be the reason
    since it's going ac3->aac audio channels are potential is why i mentioned the downmix setting
    but most likely is bandwidth limits
    there should be another log on the server than that, it should contain something that says "TranscodeReason" and that's what needs to be determined
    as far as im concerned that device should not have issues with h264 or ac3, they are fairly standard
    2023-11-19, 12:44 AM
    TranscodeReason=VideoProfileNotSupported
    Your firestick probably doesn't support h264, high 10.
    tmsrxzar
    2023-11-19, 12:52 AM (This post was last modified: 2023-11-19, 12:54 AM by tmsrxzar. Edited 1 time in total.)
    missed that, probably
    must be a 3rd gen or older, newer shows support for profile 10 https://developer.amazon.com/docs/fire-t...vstickgen3
    naopodeser
    2023-11-19, 01:04 AM
    (2023-11-19, 12:52 AM)tmsrxzar Wrote: missed that, probably
    Exacly. My Fire Stick is 4k 3rd gen. So, this is it?
    About transcode before I play. Any suggestion? Is just transcode to another profile? I'm lost about codecs, profiles, types...
    tmsrxzar
    2023-11-19, 01:14 AM
    definitely, that stick doesn't support that encoding of h264
    your server is already trying to transcode but at a rate too slow for continuous playback, note the speed= lines of your log are less than 1x
    that means the transcode is happening at less than the speed of the video, for every 1 second of playback it is only able to encode 0.5 seconds and so causing the issue
    based on your cpu im not sure if hardware acceleration would be available
    https://www.intel.com/content/www/us/en/...tions.html
    @TheDreadPirate should have a better idea on that
    might be something to try and see anyway https://jellyfin.org/docs/general/admini...celeration
    2023-11-19, 02:17 AM
    Bay Trail has quick sync, but driver support is questionable and its performance is almost certainly not sufficient to be useful.
