    Jellyfin Forum Support Troubleshooting Connection issues
    Connection issues
    Can't connect on local network Ubuntu server
    jimevt
    2025-01-25, 11:10 PM
    I have the Jellyfin server running on a Windows machine.  However, it is my wife's machine.  This makes it difficult to update, reboot, etc.
      So I'm trying to install Jellyfin on "Ubuntu 22.04.5 LTS".   I installed using the bash script method.  The jellyfin service was listed as "masked" so I unmasked it using instructions from the internet.
      I could now get to the Jellyfin login from the local machine using "localhost:8096" or "192.168.1.254:8096"   What I _couldn't_ do is use "192.168.1.254:8096" from any other machine on my local network.
       I've been trying everything I could find on the internet, but none of it has worked.
       I did set "Allow remote connections to this server", but I did not add any IP filters.
         I tried it with "ufw" disabled, enabled, enabled with 8096 allowed in many different ways.
      ufw status currently shows:
            sudo ufw status | grep 8096
            8096                      ALLOW      Anywhere
            8096 (v6)                  ALLOW      Anywhere (v6)
      Trying to access it from the brave browser reports "This site can't be reached".   firefox says the connection timed out.
       I _don't_ want to access this server from the web, only my local network.   However, I _do_ have nginx running on this machine for a mastodon server.
       All the Jellyfin nginx setups I saw seemed to be for port-forwarding with certificates for access on the web.
       How can I figure out what is going wrong?  The Jellyfin logs don't show anything when I try to connect from another host, so I'm not getting in at all.
       The ufw logs are also showing nothing when I attempt to log in.  The nginx logs do not show anything either.
      I can ping 192.168.1.254, but telnet to 192.168.1.254 8096 fails.  I _can_ ssh to this server, so at least some of the ports are accessible.
       I tried uninstalling and re-installing, but was then worried about _why_ the service was listed as masked.  I uninstalled everything and have reinstalled from the "*.deb" files.   The service is no longer listed as masked, but that still doesn't fix the local access problem.
    Thanks for your suggestions!
    JimE.
    2025-01-26, 05:11 PM
    Run these commands and share the output.
    sudo ss -tulpn | grep 8096
    sudo ufw status
    apt list --installed | grep jellyfin
    systemctl show jellyfin
    That last command will be very log. Share the output of THAT command via privatebin.net.
    jimevt
    2025-01-26, 05:23 PM
    Output is below.  Thanks again!
    : (620)>  sudo ss -tulpn | grep 8096
    tcp  LISTEN 0      512                  0.0.0.0:8096      0.0.0.0:*    users:(("jellyfin",pid=1559267,fd=466))
    : (620)> sudo ufw status
    Status: active
    To                        Action      From
    22/tcp                    ALLOW      Anywhere
    80/tcp                    ALLOW      Anywhere
    443/tcp                    ALLOW      Anywhere
    8096                      ALLOW      Anywhere
    22/tcp (v6)                ALLOW      Anywhere (v6)
    80/tcp (v6)                ALLOW      Anywhere (v6)
    443/tcp (v6)              ALLOW      Anywhere (v6)
    e: (623)> apt list --installed | grep jellyfin
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    jellyfin-ffmpeg7/unknown,now 7.0.2-9-jammy amd64 [installed]
    jellyfin-server/now 10.10.5+ubu2004 amd64 [installed,upgradable to: 10.10.5+ubu2204]
    jellyfin-web/now 10.10.5+ubu2004 all [installed,upgradable to: 10.10.5+ubu2204]
    https://privatebin.net/?83af63cba0fa6122...uw9R8oqg2N
    2025-01-26, 07:58 PM (This post was last modified: 2025-01-26, 07:59 PM by TheDreadPirate. Edited 1 time in total.)
    And this is installed directly on your machine, right? This isn't WSL2, a VM, or a LXC?
    And you're sure that 192.168.1.254 is the right IP?
    sudo ipconfig -a
    Also make sure you put "http://" before the IP. A lot of browsers won't even try http and will always assume https.
    jimevt
    2025-01-26, 08:27 PM
    This isn't a VM or anything like that.  It is my old desktop running Ubuntu.
    I think you meant "ifconfig" not "ipconfig":
    : (636)> sudo ifconfig -a
    enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.1.254  netmask 255.255.255.0  broadcast 192.168.1.255
            inet6 fe80::ba97:5aff:fe04:cc98  prefixlen 64  scopeid 0x20<link>
            ether b8:97:5a:04:cc:98  txqueuelen 1000  (Ethernet)
            RX packets 67845500  bytes 82132097767 (82.1 GB)
            RX errors 0  dropped 591020  overruns 0  frame 0
            TX packets 67070932  bytes 59481998784 (59.4 GB)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 94433730  bytes 70632115598 (70.6 GB)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 94433730  bytes 70632115598 (70.6 GB)
    jimevt
    2025-01-27, 12:07 AM (This post was last modified: 2025-01-27, 12:14 AM by jimevt. Edited 2 times in total.)
    While driving to get groceries, it occurred to me that it probably has to be nginx.  I didn't think I needed a setup as I was not trying to access this server from the web, but... What else could be inhibiting this connection?
      I created an HTTP nginx setup (provided by the jellyfin docs, replacing "jellyfin.example.org" with "192.168.1.254".
      Still no luck.
    nginx access log doesn't show anything interesting :-(
    JimE.
    jimevt
    2025-01-27, 01:12 AM
    Well! I can now get to the jellyfin server, but only if I do _NOT_ include the port in the http line.
    "http://192.168.1.254" works, "http://192.168.1.254:8096" does not.
    So, I think that my troubles have all been in the nginx setup.
    Working on getting the address with the port to work correctly.
    JimE.
    2025-01-27, 01:55 AM
    Did you configure Jellyfin to only bind to the local loopback? This would explain why local connections work on 8096, but remote connections need to go through Nginx.
    jimevt
    2025-01-27, 02:08 AM (This post was last modified: 2025-01-27, 02:39 AM by jimevt. Edited 1 time in total.)
    How do I check that?  The "ss" command showed tcp  LISTEN 0      512                  0.0.0.0:8096      0.0.0.0:*    users:(("jellyfin",pid=1559267,fd=466))
      Doesn't the "0.0.0.0" imply it is bound to any host?
    Darn it all!! After a reboot, it fails connecting again :-(
    JimE.
    jimevt
    2025-01-27, 03:28 AM
    Well.  Now I can no longer access jellyfin from the same server.
      After the reboot, nothing was listening on port 8096.  After I restarted the jellyfin service, everything worked again.
      Rebooting shouldn't break jellyfin :-(
    Jime.
