2025-01-25, 11:10 PM
I have the Jellyfin server running on a Windows machine. However, it is my wife's machine. This makes it difficult to update, reboot, etc.
So I'm trying to install Jellyfin on "Ubuntu 22.04.5 LTS". I installed using the bash script method. The jellyfin service was listed as "masked" so I unmasked it using instructions from the internet.
I could now get to the Jellyfin login from the local machine using "localhost:8096" or "192.168.1.254:8096" What I _couldn't_ do is use "192.168.1.254:8096" from any other machine on my local network.
I've been trying everything I could find on the internet, but none of it has worked.
I did set "Allow remote connections to this server", but I did not add any IP filters.
I tried it with "ufw" disabled, enabled, enabled with 8096 allowed in many different ways.
ufw status currently shows:
sudo ufw status | grep 8096
8096 ALLOW Anywhere
8096 (v6) ALLOW Anywhere (v6)
Trying to access it from the brave browser reports "This site can't be reached". firefox says the connection timed out.
I _don't_ want to access this server from the web, only my local network. However, I _do_ have nginx running on this machine for a mastodon server.
All the Jellyfin nginx setups I saw seemed to be for port-forwarding with certificates for access on the web.
How can I figure out what is going wrong? The Jellyfin logs don't show anything when I try to connect from another host, so I'm not getting in at all.
The ufw logs are also showing nothing when I attempt to log in. The nginx logs do not show anything either.
I can ping 192.168.1.254, but telnet to 192.168.1.254 8096 fails. I _can_ ssh to this server, so at least some of the ports are accessible.
I tried uninstalling and re-installing, but was then worried about _why_ the service was listed as masked. I uninstalled everything and have reinstalled from the "*.deb" files. The service is no longer listed as masked, but that still doesn't fix the local access problem.
Thanks for your suggestions!
JimE.
8096 ALLOW Anywhere
JimE.
