    Jellyfin Forum Support Troubleshooting Networking & Access connection problem to server
    ok from PC, not from DNLA nor iphone
    Cerise
    Country:France
    2025-06-13, 06:10 PM
    Hi,
    first of all, sorry for my latest posting, and not posting at the right sub-level, did it the wrong way...
    My configuration is as follow:
    - Jellyfin installed on Synology NAS running in Container Manager
    - I access movies with local network only: bluray DNLA player, iphone or PC running with Linux Mint.
    Everything was working ok until I update container with latest update. Since that time:
    - It works ok with PC (connecting to 192.168.x.xxx:8096/), but not with DNLA player nor iphone (swifin or jellyfin).
    - no other change (firewall, user ot password) has been made, so it's quite a surprise.
    Container is still running, but this message appears on NAS:
    curl (7): failed to connect to localhost port 8096 after 0ms: Couldn't connect to server
    I've seen many of you putting messages into pastebin, but I'm don't see how I can do that. I only know how to insert between HTML
    Any Idea about how to fix that ?
    Thanks for your support
    Cerise
    Country:France
    2025-06-17, 05:22 PM
    Still investigating...
    Seem weird that connecting thru http://192.168.x.x:8096 works fine on web browser, not not elsewhere.
    It means that server is running ok (I guess?), so why is there this funky message "curl (7): failed to connect to localhost port 8096 after 0ms: Couldn't connect to server" ??
    2025-06-19, 12:23 PM
    For logs: go to Dashboard > Logs. Download the logs or open and copy, then go to privatebin.net and paste or upload the log files. Separately. Without logs, not much we can do.
    Cerise
    Country:France
    2025-06-19, 07:02 PM (This post was last modified: 2025-06-19, 07:07 PM by Cerise. Edited 1 time in total.)
    Thanks Bitmap, here is the log:
    [2025-06-18 16:49:03.904 +00:00] [INF] [1] Main: Jellyfin version: "10.10.7"
    [2025-06-18 16:49:03.933 +00:00] [INF] [1] Main: Environment Variables: ["[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_PublishedServerUrl, 192.168.1.253]", "[JELLYFIN_CACHE_DIR, /cache]"]
    [2025-06-18 16:49:03.936 +00:00] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll"]
    [2025-06-18 16:49:03.936 +00:00] [INF] [1] Main: Operating system: "Debian GNU/Linux 12 (bookworm)"
    [2025-06-18 16:49:03.936 +00:00] [INF] [1] Main: Architecture: X64
    [2025-06-18 16:49:03.937 +00:00] [INF] [1] Main: 64-Bit Process: True
    [2025-06-18 16:49:03.937 +00:00] [INF] [1] Main: User Interactive: True
    [2025-06-18 16:49:03.937 +00:00] [INF] [1] Main: Processor count: 4
    [2025-06-18 16:49:03.937 +00:00] [INF] [1] Main: Program data path: "/config"
    [2025-06-18 16:49:03.938 +00:00] [INF] [1] Main: Log directory path: "/config/log"
    [2025-06-18 16:49:03.938 +00:00] [INF] [1] Main: Config directory path: "/config/config"
    [2025-06-18 16:49:03.938 +00:00] [INF] [1] Main: Cache path: "/cache"
    [2025-06-18 16:49:03.938 +00:00] [INF] [1] Main: Temp directory path: "/tmp/jellyfin"
    [2025-06-18 16:49:03.938 +00:00] [INF] [1] Main: Web resources path: "/jellyfin/jellyfin-web"
    [2025-06-18 16:49:03.938 +00:00] [INF] [1] Main: Application directory: "/jellyfin/"
    [2025-06-18 16:49:04.174 +00:00] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: "/cache"
    [2025-06-18 16:49:04.284 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
    [2025-06-18 16:49:04.301 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Rssdp, Version=8.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/DLNA_8.0.0.0/Rssdp.dll"
    [2025-06-18 16:49:04.303 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Jellyfin.Plugin.Dlna.Model, Version=8.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/DLNA_8.0.0.0/Jellyfin.Plugin.Dlna.Model.dll"
    [2025-06-18 16:49:04.310 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Jellyfin.Plugin.Dlna, Version=8.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/DLNA_8.0.0.0/Jellyfin.Plugin.Dlna.dll"
    [2025-06-18 16:49:04.313 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Jellyfin.Plugin.Dlna.Playback, Version=8.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/DLNA_8.0.0.0/Jellyfin.Plugin.Dlna.Playback.dll"
    [2025-06-18 16:49:04.424 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [2025-06-18 16:49:04.424 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions: []
    [2025-06-18 16:49:04.424 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Used LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [2025-06-18 16:49:04.426 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Filtered interface addresses: ["192.168.1.253"]
    [2025-06-18 16:49:04.427 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Bind Addresses ["192.168.1.253"]
    [2025-06-18 16:49:04.428 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Remote IP filter is "Allowlist"
    [2025-06-18 16:49:04.428 +00:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Filtered subnets: []
    [2025-06-18 16:49:07.946 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "DLNA" "8.0.0.0"
    [2025-06-18 16:49:07.948 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TMDb" "10.10.7.0"
    [2025-06-18 16:49:07.949 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Studio Images" "10.10.7.0"
    [2025-06-18 16:49:07.949 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "OMDb" "10.10.7.0"
    [2025-06-18 16:49:07.985 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "MusicBrainz" "10.10.7.0"
    [2025-06-18 16:49:07.985 +00:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "AudioDB" "10.10.7.0"
    [2025-06-18 16:49:08.166 +00:00] [INF] [1] Main: Kestrel is listening on "192.168.1.253"
    [2025-06-18 16:49:08.194 +00:00] [INF] [1] Jellyfin.Plugin.Dlna.DlnaManager: Using user profile directory "/config/plugins/configurations/dlna/user"
    [2025-06-18 16:49:08.197 +00:00] [INF] [1] Jellyfin.Plugin.Dlna.DlnaManager: Using system profile directory "/config/plugins/DLNA_8.0.0.0/profiles"
    [2025-06-18 16:49:08.420 +00:00] [INF] [1] Jellyfin.Plugin.Dlna.Main.DlnaHost: Registering publisher for "urn:schemas-upnp-org:device:MediaServer:1" on "192.168.1.253" with uri "http://192.168.1.253:8096/media/dlna/ac6f26b7-009c-4fb7-9f4d-a18dab07c7b6/description.xml"
    [2025-06-18 16:49:09.678 +00:00] [WRN] [1] Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware: The WebRootPath was not found: "/wwwroot". Static files may be unavailable.
    [2025-06-18 16:49:09.756 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
    [2025-06-18 16:49:09.788 +00:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Générer des images Trickplay" set to fire at 2025-06-19 03:00:00.000 +00:00, which is 10:10:50.2114505 from now.
    [2025-06-18 16:49:09.798 +00:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Extraire les images de chapitre" set to fire at 2025-06-19 02:00:00.000 +00:00, which is 09:10:50.2013433 from now.
    [2025-06-18 16:49:09.842 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version "7.0.2"
    [2025-06-18 16:49:09.936 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "ac4", "dca", "flac", "mp3", "truehd"]
    [2025-06-18 16:49:09.965 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "encoders": ["libsvtav1", "av1_nvenc", "av1_qsv", "av1_amf", "av1_vaapi", "libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mjpeg_qsv", "mjpeg_vaapi", "aac", "libfdk_aac", "ac3", "alac", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
    [2025-06-18 16:49:09.994 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["bwdif_cuda", "deinterlace_qsv", "deinterlace_vaapi", "flip_vulkan", "hwupload_cuda", "hwupload_vaapi", "libplacebo", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_vulkan", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "scale_vulkan", "tonemapx", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "transpose_cuda", "transpose_opencl", "transpose_vaapi", "transpose_vulkan", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
    [2025-06-18 16:49:10.175 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
    [2025-06-18 16:49:12.815 +00:00] [INF] [11] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Nettoyer le dossier des transcodages" Completed after 0 minute(s) and 0 seconds
    [2025-06-18 16:49:12.827 +00:00] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Nettoyer les collections et les listes de lecture" Completed after 0 minute(s) and 0 seconds
    [2025-06-18 16:49:13.807 +00:00] [INF] [16] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Mettre à jour les extensions" Completed after 0 minute(s) and 0 seconds
    [2025-06-18 16:49:15.570 +00:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
    [2025-06-18 16:49:15.570 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: "ac6f26b7009c4fb79f4da18dab07c7b6"
    [2025-06-18 16:49:15.570 +00:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
    [2025-06-18 16:49:15.571 +00:00] [INF] [1] Main: Startup complete 0:00:11.8986482
    [2025-06-18 16:51:31.223 +00:00] [INF] [19] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.10" request
    [2025-06-18 16:51:42.472 +00:00] [INF] [21] Jellyfin.Plugin.Dlna.Main.DlnaHost: DLNA Session created for "BDP-S6700" - "BDP-S6700" using profile "Sony Blu-ray Player 2016"
    Cerise
    Country:France
    2025-06-19, 07:14 PM
    Something new into the log. I guess I didn't not allow enough time to have the information fully written into it.
    Here it is, with error in the last lines.
    [2025-06-18 17:02:30.719 +00:00] [INF] [27] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.10" closed
    [2025-06-18 17:02:31.447 +00:00] [INF] [23] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.10" request
    [2025-06-18 17:03:19.203 +00:00] [INF] [3] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.10" closed
    [2025-06-18 17:04:10.485 +00:00] [INF] [24] Jellyfin.Plugin.Dlna.Main.DlnaHost: DLNA Session created for "BDP-S6700" - "BDP-S6700" using profile "Sony Blu-ray Player 2016"
    [2025-06-18 17:04:11.490 +00:00] [ERR] [28] Jellyfin.Plugin.Dlna.Main.DlnaHost: Error updating device info for "BDP-S6700"
    System.Net.Http.HttpRequestException: Connection refused (192.168.1.55:52323)
    ---> System.Net.Sockets.SocketException (111): Connection refused
      at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
      at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)
      at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|285_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
      at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
      at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.<SendCoreAsync>g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
      at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.<SendCoreAsync>g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
      at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
      at Jellyfin.Plugin.Dlna.PlayTo.DlnaHttpClient.SendRequestAsync(HttpRequestMessage request, CancellationToken cancellationToken)
      at Jellyfin.Plugin.Dlna.PlayTo.DlnaHttpClient.GetDataAsync(String url, CancellationToken cancellationToken)
      at Jellyfin.Plugin.Dlna.PlayTo.Device.GetAVProtocolAsync(CancellationToken cancellationToken)
      at Jellyfin.Plugin.Dlna.PlayTo.Device.TimerCallback(Object sender)
