    Jellyfin Forum Support Troubleshooting connection problems
    connection problems
    How to set up a path to my nas
    Ricochez
    Country:Netherlands
    2025-11-20, 12:59 PM
    Hi,
    I have a Synology nas (RS816) running DSM 7.2 where I have all my media-files. I can't install Jellyfin on it because I can't install docker or container manager. On my mac I have jellyfin installed and I'm trying to set a path to my nas, but somehow I can't get Jellyfin to find my nas, let alone my shared video-folder on the nas. Is this even possible and if so, can somebody point me in the right direction? I gave Jellyfin full access to my mac, but I can't figure out a path to my nas to set up a media-library.
    Regards
    Rico
    jellykrabbypatty
    Threads: 31
    2025-11-20, 05:32 PM
    (2025-11-20, 12:59 PM)Ricochez Wrote: Hi,
    Regards
    Rico
    I'm confused. Isn't the point of NAS to have Jellyfin running direct from it like a standalone PC? Why does docker or container manager not work?
    I complain about Jellyfin a lot and have no idea what I'm doing.
    pxr5
    2025-11-20, 08:38 PM (This post was last modified: 2025-11-20, 08:39 PM by pxr5. Edited 1 time in total.)
    ^ Docker (Container Manager) will only run on + models of Synology NAS.
    To the OP. How do you normally access any files on your NAS from the Mac? The way to handle this is map NAS folders to a Drive letter on your Mac. I enable NFS access on my video folders (Movie and TV) on my NAS. A quick google should show you how to do this on a Mac. I then map them to a drive letter (this is Win11 btw) like this from Windows Explorer:
    map network movie drive to
    192.168.x.xxx:/volume1\video3\Movie
    map network TV drive and
    192.168.x.xxx:/volume1\video3\TV
    Once you can view the movie/tv folders on your mac via a mapped drive go to Jellyfin and add new library and select the mapped drive as required. e.g. Z:\
    Jellyfin1 - 10.11.5 Synology NAS (transcoding off)
    Jellyfin2 - 10.11.5 Minix ZX100-0db MiniPC, Intel N100 (transcoding on)
    Storage - x4 Synology NAS (70TB)
    Reverse Proxy - Caddy v2 running on a Pi3b+
    Ricochez
    Country:Netherlands
    2025-11-24, 11:11 AM
    @jellykrabbypatty, I'm not complaining at Jellyfin, I'm asking how something is done. I'm new to Jellyfin. As for why docker or containermanager doesn't work, I don't know. Synology dropped the support with DSM 7.2
    @pxr5, normally I access my Nas via Chrome, that's how I put my media-files on it. Somehow my tv has access right away but when setting up a library in Jellyfin I can't find a way to access my nas within Jellyfin. NFS access is enabled. I will try if I can map the video-folder to a drive letter. Thanks
