    Pages (12): « Previous 1 … 7 8 9 10 11 12 Next »
    • 2 Vote(s) - 5 Average
    2025-02-16, 07:38 PM
    You should be able to open a bash shell into the Jellyfin container. I can't remember if unRAID has a button in the UI to do this, but you should be able to do this from the unRAID terminal.
    docker exec -it jellyfin bash
    That will open a bash shell into the jellyfin container and then you can follow the guide.
    Jellyfin 12.2 (Docker)
    Shawn Farley
    2025-02-16, 08:33 PM (This post was last modified: 2025-02-16, 08:43 PM by Shawn Farley. Edited 1 time in total.)
    So I got it to work.
    root@68d53661c0aaConfused-face# /usr/lib/jellyfin-ffmpeg/ffmpeg -y -hide_banner -stats -fflags +genpts+igndts -loglevel error -i "/data/temp/Test/Alien.1979.Directors.Cut.HYBRID.2160p.BluRay.REMUX.HEVC.DV.DTS-HD.MA.5.1-Flights.mkv" -map 0 -bsf:v hevc_metadata=remove_dovi=1 -codec copy -max_muxing_queue_size 2048 -max_interleave_delta 0 -avoid_negative_ts disabled hdr10_video.mkv
    size=45063137KiB time=01:52:38.25 bitrate=54623.2kbits/s speed=57.9x
    But when I check Media info it still shows profile 8.1
    2025-02-16, 10:14 PM
    Did you replace the original with the new file?
    Shawn Farley
    2025-02-16, 10:25 PM
    No I was checking the new file before I replace it.
    2025-02-16, 10:30 PM
    You'd have to show the output of media info. Or ffprobe.
    Shawn Farley
    2025-02-16, 10:55 PM
    How do I use FFprob
    Shawn Farley
    2025-02-17, 12:10 AM
    Heres an image of the media information from the file I copied to test folder and ran the script on.
    2025-02-17, 01:19 AM
    You'd open the bash prompt for the Jellyfin container again. ffprobe is in the same folder as ffmpeg. Just run that command and provide a file path for the new video.
    Shawn Farley
    2025-02-17, 01:38 AM
    Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
    Metadata:
    title :
    Side data:
    DOVI configuration record: version: 1.0, profile: 8, level: 6, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 1
    Stream #0:1(eng): Audio: dts (dca) (DTS-HD MA), 48000 Hz, 5.1(side), s32p (24 bit) (default)
    Metadata:
    title :
    Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle (pgssub) (default)
    Metadata:
    title :
    Stream #0:3(spa): Subtitle: hdmv_pgs_subtitle (pgssub)
    Metadata:
    title : Spanish (Latin American)
    Stream #0:4(spa): Subtitle: hdmv_pgs_subtitle (pgssub)
    Metadata:
    title : Spanish (Castilian)
    Stream #0:5(fre): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:6(dan): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:7(dut): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:8(fin): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:9(ger): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:10(ita): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:11(nor): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:12(swe): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:13(chi): Subtitle: hdmv_pgs_subtitle (pgssub)
    Metadata:
    title : Chinese (Traditional)
    Stream #0:14(chi): Subtitle: hdmv_pgs_subtitle (pgssub)
    Metadata:
    title : Chinese (Simplified)
    Stream #0:15(cze): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:16(kor): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:17(pol): Subtitle: hdmv_pgs_subtitle (pgssub)
    Stream #0:18(tha): Subtitle: hdmv_pgs_subtitle (pgssub)
    [STREAM]
    index=0
    codec_name=hevc
    codec_long_name=H.265 / HEVC (High Efficiency Video Coding)
    profile=Main 10
    codec_type=video
    codec_tag_string=[0][0][0][0]
    codec_tag=0x0000
    width=3840
    height=2160
    coded_width=3840
    coded_height=2160
    closed_captions=0
    film_grain=0
    has_b_frames=1
    sample_aspect_ratio=1:1
    display_aspect_ratio=16:9
    pix_fmt=yuv420p10le
    level=153
    color_range=tv
    color_space=bt2020nc
    color_transfer=smpte2084
    color_primaries=bt2020
    chroma_location=topleft
    field_order=unknown
    refs=1
    id=N/A
    r_frame_rate=24000/1001
    avg_frame_rate=24000/1001
    time_base=1/1000
    start_pts=0
    start_time=0.000000
    duration_ts=N/A
    duration=N/A
    bit_rate=N/A
    max_bit_rate=N/A
    bits_per_raw_sample=N/A
    nb_frames=N/A
    nb_read_frames=N/A
    nb_read_packets=N/A
    extradata_size=750
    DISPOSITION:default=1
    DISPOSITION:dub=0
    DISPOSITIONFace-with-open-mouthriginal=0
    DISPOSITION:comment=0
    DISPOSITION:lyrics=0
    DISPOSITION:karaoke=0
    DISPOSITION:forced=0
    DISPOSITION:hearing_impaired=0
    DISPOSITION:visual_impaired=0
    DISPOSITION:clean_effects=0
    DISPOSITION:attached_pic=0
    DISPOSITION:timed_thumbnails=0
    DISPOSITION:non_diegetic=0
    DISPOSITION:captions=0
    DISPOSITION:descriptions=0
    DISPOSITION:metadata=0
    DISPOSITION:dependent=0
    DISPOSITION:still_image=0
    TAG:title=
    [SIDE_DATA]
    side_data_type=DOVI configuration record
    dv_version_major=1
    dv_version_minor=0
    dv_profile=8
    dv_level=6
    rpu_present_flag=1
    el_present_flag=0
    bl_present_flag=1
    dv_bl_signal_compatibility_id=1
    [/SIDE_DATA]
    [/STREAM]
    [STREAM]
    index=1
    codec_name=dts
    codec_long_name=DCA (DTS Coherent Acoustics)
    profile=DTS-HD MA
    codec_type=audio
    codec_tag=0x0000
    sample_fmt=s32p
    sample_rate=48000
    channels=6
    channel_layout=5.1(side)
    bits_per_sample=0
    initial_padding=0
    id=N/A
    r_frame_rate=0/0
    avg_frame_rate=0/0
    time_base=1/1000
    start_pts=0
    start_time=0.000000
    duration_ts=N/A
    duration=N/A
    bit_rate=N/A
    max_bit_rate=N/A
    bits_per_raw_sample=24
    nb_frames=N/A
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:dub=0
    TAG:language=eng
    TAG:title=
    [/STREAM]
    2025-02-17, 03:05 PM
    Is that the ffprobe of the new file or the original file? The ffmpeg command you ran to convert it wouldn't have directly replaced the original. It would have written the file in the direct you were currently in. Looking at what you pasted earlier, you were in "/". The top level directory, which is part of the temporary container storage and not permanent.
    Go back into the container's bash shell and look in / for the file.
