    Jellyfin Forum Support Troubleshooting DVR recording offset due to live stream delay
    Streams delayed causing recordings to be cut off and start to early
    Yuuichi
    2025-06-06, 10:03 PM (This post was last modified: 2025-06-06, 10:39 PM by Yuuichi. Edited 2 times in total.)
    I use the DVR function to record m3u streams. I have everything recording correctly. The only issue I have is there is about a 2 minute delay in the video stream. So my recordings start at the correct time in the EPG but the recording is 2 minutes behind. So at the end of the recording it stops 2 minutes early.
    Example :
    Show starts at 8:00 PM and end 8:30 PM. DVR records the show as scheduled.
    The show itself time stamp when played back is 7:58 PM to 8:28 PM.
    I have tried setting the stop when possible but when there are multiple episodes together it doesn't stop late. Start when possible doesn't allow negative numbers.
    Is there a way to shift the EPG a couple minutes? I run Jellyfin in a docker so I don't know if I can change the time just in the docker container.
    Any help would be great.
    Thanks
