    Jellyfin Forum Support Troubleshooting Fix for audio pause bug when using passthrough on Linux
    VladtheImpaler
    2024-06-12, 05:55 PM
    I've had a long term problem with Jellyfin Media Player on pipewire. When passing AC3 or DTS over spdif and pausing a video, it would cause audio to start looping the last sound played over and over really fast. It was truly annoying.
    It did with every version I tried, the Deb version, the Snap version, the AUR version, the Copr version, building it myself..  It did it on both of my receivers, 1 new Onkyo and 1 old Harmon Kardon. I did it with multiple audio devices, the Soundblaster Z and AE-5 Plus and the Realtek 892 and 1220.
    The fix is to change pipewires period-size and headroom.  I've confirmed the fix works on 3 different PC's.  It's possible lower settings will also work, but I'm leaving them at 1024 and 8192 until I encounter problems.
    Wireplumber 0.5 and newer
    create:  ~/.config/wireplumber/wireplumber.conf.d/50-alsa-config.conf
    add:
    monitor.alsa.rules = [
        matches = [
            ## Matches all sources.
            node.name = "~alsa_input.*"
            ## Matches all sinks.
            node.name = "~alsa_output.*"
        actions = {
          update-props = {
            session.suspend-timeout-seconds = 0
            api.alsa.period-size = 1024
            api.alsa.headroom = 8192
    Wireplumber older than 0.5
    sudo cp -a /usr/share/wireplumber/main.lua.d/50-alsa-config.lua ~/.config/wireplumber/main.lua.d/50-alsa-config.lua
    Scroll to the bottom and change:  (remove -- to uncomment)
          ["api.alsa.period-size"]  = 1024,
          ["api.alsa.headroom"]    = 8192,
          --["api.alsa.disable-mmap"]  = false,
          --["api.alsa.disable-batch"] = false,
          ["session.suspend-timeout-seconds"] = 0
    Reboot or restart wireplumber
    systemctl --user restart wireplumber
