    Jellyfin Forum Support Troubleshooting Fix Hardware Acceleration using QSV not working.
    Pages (3): 1 2 3 Next »
    jimmythejuicer24
    2023-12-05, 05:56 AM
    As the title reads, I'm trying to get hardware acceleration to work using QSV.
    Specs:
    - Ubuntu 22.04.3 LTS
    - Intel i5-6400
    - Jellyfin Version 10.8.13 (through docker)
    FFmpeg logs:
    ffmpeg version 5.1.2-Jellyfin Copyright © 2000-2022 the FFmpeg developers
      built with gcc 10 (Debian 10.2.1-6)
      configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-libs=-lfftw3f --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-shared --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-static --enable-gmp --enable-gnutls --enable-chromaprint --enable-libdrm --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libdav1d --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libsvtav1 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-opencl --enable-vaapi --enable-amf --enable-libmfx --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
    [AVHWDeviceContext @ 0x55b300a79f00] No VA display found for any default device.
    Device creation failed: -22.
    Failed to set value 'vaapi=va:,driver=iHD,kernel_driver=i915' for option 'init_hw_device': Invalid argument
    Error parsing global options: Invalid argument
    Checking QSV support:
    sudo /usr/lib/jellyfin-ffmpeg/vainfo --display drm --device /dev/dri/renderD128
    Trying display: drm
    libva info: VA-API version 1.20.0
    libva info: Found init function __vaDriverInit_1_20
    vainfo: VA-API version: 1.20 (libva 2.20.0)
    vainfo: Driver version: Intel iHD driver for Intel® Gen Graphics - 23.4.0 (05e4d0d)
          VAProfileMPEG2Simple            : VAEntrypointEncSlice
          VAProfileMPEG2Main              : VAEntrypointEncSlice
          VAProfileH264Main              : VAEntrypointFEI
          VAProfileH264High              : VAEntrypointFEI
          VAProfileH264ConstrainedBaseline: VAEntrypointFEI
          VAProfileVP8Version0_3          : VAEntrypointVLD
          VAProfileVP8Version0_3          : VAEntrypointEncSlice
          VAProfileHEVCMain              : VAEntrypointEncSlice
          VAProfileHEVCMain              : VAEntrypointFEI
    Checking OpenCL Runtime:
    sudo /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=vaConfused-facedev/dri/renderD128 -init_hw_device opencl@va
    ffmpeg version 6.0.1-Jellyfin Copyright © 2000-2023 the FFmpeg developers
      configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-libdrm --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libsvtav1 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-opencl --enable-vaapi --enable-amf --enable-libvpl --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
    [AVHWDeviceContext @ 0x5599240554c0] libva: VA-API version 1.20.0
    [AVHWDeviceContext @ 0x5599240554c0] libva: Trying to open /usr/lib/jellyfin-ffmpeg/lib/dri/iHD_drv_video.so
    [AVHWDeviceContext @ 0x5599240554c0] libva: Found init function __vaDriverInit_1_20
    [AVHWDeviceContext @ 0x5599240554c0] libva: va_openDriver() returns 0
    [AVHWDeviceContext @ 0x5599240554c0] Initialised VAAPI connection: version 1.20
    [AVHWDeviceContext @ 0x5599240554c0] VAAPI driver: Intel iHD driver for Intel® Gen Graphics - 23.4.0 (05e4d0d).
    [AVHWDeviceContext @ 0x5599240554c0] Driver not found in known nonstandard list, using standard behaviour.
    [AVHWDeviceContext @ 0x559924077980] 0.0: Intel® OpenCL HD Graphics / Intel® HD Graphics 530 [0x1912]
    [AVHWDeviceContext @ 0x559924077980] Intel QSV to OpenCL mapping function found (clCreateFromVA_APIMediaSurfaceINTEL).
    [AVHWDeviceContext @ 0x559924077980] Intel QSV in OpenCL acquire function found (clEnqueueAcquireVA_APIMediaSurfacesINTEL).
    [AVHWDeviceContext @ 0x559924077980] Intel QSV in OpenCL release function found (clEnqueueReleaseVA_APIMediaSurfacesINTEL).
    I'm not sure what's wrong, all the permissions are fine. I did a last resort move and did 'chmod -R 777 /dev/dri' but it still didn't work. I've installed everything necessary on the website, what am I missing?
    2023-12-05, 02:41 PM
    The "validation" commands you ran were run on Ubuntu? Did you pass the GPU into the container? Can you share your docker command/docker compose?
    jimmythejuicer24
    2023-12-05, 08:12 PM
    Yes I ran the validation commands on Ubuntu, that's what I'm using
    Here is the contents of docker-compose.yml:
    version: '23.0.0'
    image: jellyfin/jellyfin:latest
    container_name: jellyfin
    user: 1000:1000
    group_add:
    - "109"
    - "44"
    network_mode: 'bridge'
    ports:
    - 8096:8096
    - /home/lendro/jellyfin/configConfused-faceconfig
    - /home/lendro/jellyfin/cacheConfused-facecache
    - /home/lendro/jellyfin/mediaConfused-facemedia:ro
    devices:
    - /dev/dri/renderD128Confused-facedev/dri/renderD128
    - /dev/dri/card0Confused-facedev/dri/card0
    restart: 'unless-stopped'
    2023-12-05, 08:15 PM
    On the host system you added your user to the render group? And you don't need to pass card0 into the container, AFAIK.
    jimmythejuicer24
    2023-12-05, 08:45 PM
    I thought I fixed it with this but it still doesn't work:
    version: '23.0.0'
    group_add:
    - "109"
    - "44"
    environment:
    - PUID=1000
    - PGID=1000
    - TZ=America/Los_Angeles
    - VERSION=docker
    ports:
    - 8096:8096
    devices:
    - /dev/driConfused-facedev/dri
    I still can't figure out what's wrong
    2023-12-05, 08:54 PM
    What is the output of
    id lendro
    jimmythejuicer24
    2023-12-05, 09:24 PM
    uid=1000(lendro) gid=1000(lendro) groups=1000(lendro),4(adm),24(cdrom),27(sudo),30(dip),44(video),46(plugdev),106(input),109(render),110(lxd),999(docker)
    2023-12-05, 09:46 PM
    I know you have a UID and GID in the environment config, but I think you also need
    user: 1000:1000
    https://jellyfin.org/docs/general/admini...ualization
    jimmythejuicer24
    2023-12-05, 10:10 PM
    version: '23.0.0'
    user: 1000:1000
    group_add:
    - "109"
    - "44"
    environment:
    - PUID=1000
    - PGID=1000
    - VERSION=docker
    ports:
    - 8096:8096
    devices:
    Still doesn't work for me. Do you think it's possible that the changes aren't being updated? I added the line for timezone but the time stamps in the logs are still wrong.
    2023-12-05, 10:15 PM
    If you are running "docker-compose down" before upping again, it should be pulling in any changes to the compose file. Try recreating the container.
    docker-compose up --force-recreate
