    Jellyfin Forum Support Troubleshooting Hardware Acceleration and Docker
    Pages (3): 1 2 3 Next »
    Jellyfin on Docker Engine hardware acceleration with a P400
    missmintygreen
    2024-06-12, 01:08 AM
    Jellyfin version: 10.9.6
    Install method: Docker Engine container
    CPU: Intel i5 3470
    GPU: Nvidia Quadro P400
    New to Linux and I've managed to get a Docker install with Home Assistant and Jellyfin up and running. While video playback works just fine in Chrome, in the Jellyfin app, and on Swiftfin on my AppleTV, I picked up a GPU because I'd like to take some of the load off the CPU so that I can share access to my media library with some friends in the future. The majority of my movies and shows are just MKV files, and when I switch on hardware acceleration on the Dashboard, I'm not able to play back any of my media until it's switched off again.
    I've tried to install the proper GPU driver for my P400, but I'm not sure that Jellyfin has proper access to it. I've been a bit confused by the directions on the Jellyfin website, considering my installation method. I'm relatively certain jellyfin-ffmpeg was installed when I created the container, so I think it's just a matter of configuring my GPU to work with Docker and Jellyfin.
    2024-06-12, 01:34 AM
    How much of this guide did you read?
    https://jellyfin.org/docs/general/admini...ial-docker
    missmintygreen
    2024-06-12, 02:00 AM (This post was last modified: 2024-06-12, 02:02 AM by missmintygreen. Edited 1 time in total.)
    (2024-06-12, 01:34 AM)TheDreadPirate Wrote: How much of this guide did you read?
    I'll be honest, I was trying to follow that guide, however, I mistakenly worked off the Linux host section. I believe I downloaded the driver on the host system. I tried installing a driver, but I'm not sure if it actually worked.
    When I ran
    sudo apt update && sudo apt install -y libnvidia-decode libnvidia-encode
    I got this.
    Package libnvidia-decode is a virtual package provided by:
      libnvidia-decode-550-server 550.54.15-0ubuntu0.22.04.2
      libnvidia-decode-550 550.67-0ubuntu1.22.04.2
      libnvidia-decode-545 545.29.06-0ubuntu0.22.04.2
      libnvidia-decode-535-server 535.161.08-0ubuntu2.22.04.1
      libnvidia-decode-535 535.171.04-0ubuntu0.22.04.1
      libnvidia-decode-470-server 470.239.06-0ubuntu0.22.04.1
      libnvidia-decode-470 470.239.06-0ubuntu0.22.04.1
      libnvidia-decode-450-server 450.248.02-0ubuntu0.22.04.1
      libnvidia-decode-418-server 418.226.00-0ubuntu5~0.22.04.1
      libnvidia-decode-390 390.157-0ubuntu0.22.04.2
    You should explicitly select one to install.
    Package libnvidia-encode is a virtual package provided by:
      libnvidia-encode-550-server 550.54.15-0ubuntu0.22.04.2
      libnvidia-encode-550 550.67-0ubuntu1.22.04.2
      libnvidia-encode-545 545.29.06-0ubuntu0.22.04.2
      libnvidia-encode-535-server 535.161.08-0ubuntu2.22.04.1
      libnvidia-encode-535 535.171.04-0ubuntu0.22.04.1
      libnvidia-encode-470-server 470.239.06-0ubuntu0.22.04.1
      libnvidia-encode-470 470.239.06-0ubuntu0.22.04.1
      libnvidia-encode-450-server 450.248.02-0ubuntu0.22.04.1
      libnvidia-encode-418-server 418.226.00-0ubuntu5~0.22.04.1
      libnvidia-encode-390 390.157-0ubuntu0.22.04.2
    E: Package 'libnvidia-decode' has no installation candidate
    E: Package 'libnvidia-encode' has no installation candidate
    I'm not sure how to explicitly select one, or which is even the correct driver to use.
    Do I just add a hyphen and the driver number?
    2024-06-12, 03:33 PM
    You explicitly select one by typing it in.
    sudo apt install libnvidia-encode-550 libnvidia-decode-550
    missmintygreen
    2024-06-12, 10:08 PM
    (2024-06-12, 03:33 PM)TheDreadPirate Wrote: You explicitly select one by typing it in.
    Okay, so I got all the way through this after installing the driver and the container toolkit, but on step 6, I input this
    docker exec -it jellyfin nvidia-smi
    and got this
    OCI runtime exec failed: exec failed: unable to start container process: exec: "nvidia-smi": executable file not found in $PATH: unknown
    I'm not sure where I went wrong. The rest of the process went pretty smoothly.
    2024-06-12, 10:11 PM (This post was last modified: 2024-06-12, 10:12 PM by TheDreadPirate. Edited 1 time in total.)
    Step number 2. Did you install the Nvidia container toolkit? Because why would Nvidia make things simple for us?
    Also, can you share your docker compose file with us?
    missmintygreen
    2024-06-12, 10:21 PM
    (2024-06-12, 10:11 PM)TheDreadPirate Wrote: Step number 2.  Did you install the Nvidia container toolkit?  Because why would Nvidia make things simple for us?
    Yes, I did install the container toolkit! Can't have it be too easy or everyone would be doing it.
    Here's my compose file!
        image: jellyfin/jellyfin
        container_name: jellyfin
        network_mode: 'host'
          - /home/me/jellyfin:/config
          - /home/me/jellyfin:/cache
          - type: bind
            source: /media/me/library/Movies
            target: /Movies
          - type: bind
            source: /media/me/library/Shows
            target: /Shows
            read_only: true
        restart: 'unless-stopped'
        runtime: nvidia
        deploy:
          resources:
            reservations:
              devices:
                - capabilities: [gpu]
    2024-06-12, 10:29 PM (This post was last modified: 2024-06-12, 10:30 PM by TheDreadPirate. Edited 1 time in total.)
    Does nvidia-smi work on the host system?
    On the host what is the output "sudo apt list --installed | grep header"
    missmintygreen
    2024-06-12, 10:34 PM
    (2024-06-12, 10:29 PM)TheDreadPirate Wrote: Does nvidia-smi work on the host system?
    nvidia-smi returned this
    Wed Jun 12 18:34:10 2024
    | NVIDIA-SMI 535.171.04            Driver Version: 535.171.04  CUDA Version: 12.2    |
    | GPU  Name                Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
    | Fan  Temp  Perf          Pwr:Usage/Cap |        Memory-Usage | GPU-Util  Compute M. |
    |                                        |                      |              MIG M. |
    |  0  Quadro P400                    Off | 00000000:01:00.0 Off |                  N/A |
    | 34%  34C    P8              N/A /  N/A |    150MiB /  2048MiB |      0%      Default |
    |                                        |                      |                  N/A |
    | Processes:        |
    |  GPU  GI  CI        PID  Type  Process name                            GPU Memory |
    |        ID  ID                                                            Usage      |
    |    0  N/A  N/A      854      G  /usr/lib/xorg/Xorg                          64MiB |
    |    0  N/A  N/A      1121      G  /usr/bin/gnome-shell                        59MiB |
    I got this back from "sudo apt lost --installed | grep header"
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    linux-headers-6.5.0-28-generic/jammy-updates,jammy-security,now 6.5.0-28.29~22.04.1 amd64 [installed,automatic]
    linux-headers-6.5.0-35-generic/jammy-updates,jammy-security,now 6.5.0-35.35~22.04.1 amd64 [installed,automatic]
    linux-headers-generic-hwe-22.04/jammy-updates,jammy-security,now 6.5.0.35.35~22.04.1 amd64 [installed,automatic]
    linux-hwe-6.5-headers-6.5.0-28/jammy-updates,jammy-updates,jammy-security,jammy-security,now 6.5.0-28.29~22.04.1 all [installed,automatic]
    linux-hwe-6.5-headers-6.5.0-35/jammy-updates,jammy-updates,jammy-security,jammy-security,now 6.5.0-35.35~22.04.1 all [installed,automatic]
    2024-06-12, 10:41 PM
    I'm wondering if there are mismatched drivers or something. Since you're using Ubuntu you can check out their documentation or Nvidia drivers. Ubuntu includes some tools to make things easier.
    https://ubuntu.com/server/docs/nvidia-dr...stallation
