    Jellyfin Forum Support Troubleshooting Hardware Acceleration Issue on N150 Processor
    Unstirred6783
    2025-07-26, 12:11 PM
    I'm using a Beelink S13 Mini PC Intel N150 Processor.
    I installed Debian 12 on the PC and also Jellyfin via the Jellyfin website's official instructions.
    I then made sure the Kernel was up to date, the Intel drivers were installed etc via the non-free backport repository.
    I installed Mesa, Intel Graphics, Linux Firwmare, etc.
    Then I went into my Jellyfin dashboard and enabled Transcoding Hardware Acceleration via Intel QuickSync (QSV)
    My settings look like this:
    QSV Device:
    /dev/dri/renderD128
    Enable hardware decoding for
    H264
    HEVC
    MPEG2
    VC1  VP8
    VP9
    AV1
    HEVC 10bit  (The only one unchecked, as this is the only one that caused me issues)
    VP9 10bit
    HEVC RExt 8/10bit
    HEVC RExt 12bit
    Prefer OS native DXVA or VA-API hardware decoders
    Hardware Encoding Options:
    Enable Intel Low-Power H.264 hardware encoder
    Enable Intel Low-Power HEVC hardware encoder
    My problem is:
    If I check the "Enable Hardware Encoding" option, it causes me to get a "Fatal Playback Error" that states the following: "Playback Error Playback failed due to a fatal player error."
    If I go and uncheck the "Enable Hardware Encoding" option, then my playback works but I suspect it's not using QuickSync and it takes forever to seek etc.
    Has anyone had this issue before, what can I do to troubleshoot this / fix it?
    Thanks!
    nyanmisaka
    2025-07-26, 02:02 PM
    Please share the output of sudo dmesg | grep i915 and the FFmpeg logs containing the transcoding errors.
    Unstirred6783
    2025-07-26, 05:35 PM
    (2025-07-26, 02:02 PM)nyanmisaka Wrote: Please share the output of sudo dmesg | grep i915 and the FFmpeg logs containing the transcoding errors.
    output of sudo dmesg | grep i915:
    [    2.141855] i915 0000:00:02.0: [drm] Found ALDERLAKE_P/ADL-N (device ID 46d4) display version 13.00 stepping D0
    [    2.142347] i915 0000:00:02.0: [drm] VT-d active for gfx access
    [    2.142451] i915 0000:00:02.0: vgaarb: deactivate vga console
    [    2.142495] i915 0000:00:02.0: [drm] Using Transparent Hugepages
    [    2.142640] i915 0000:00:02.0: [drm] Port B asks to use VBT vswing/preemph tables
    [    2.142656] WARNING: CPU: 3 PID: 194 at drivers/gpu/drm/i915/display/intel_bios.c:2698 intel_bios_init+0xe78/0x19d0 [i915]
    [    2.142841] Modules linked in: i915(+) drm_buddy i2c_algo_bit drm_display_helper spi_pxa2xx_platform dw_dmac sd_mod cec dw_dmac_core rc_core spi_pxa2xx_core xhci_pci ttm ahci libahci xhci_hcd r8169 drm_kms_helper realtek usbcore libata mdio_devres crc32_pclmul drm scsi_mod crc32c_intel libphy i2c_i801 scsi_common i2c_smbus intel_lpss_pci intel_lpss idma64 usb_common fan video wmi pinctrl_alderlake button
    [    2.142866] RIP: 0010:intel_bios_init+0xe78/0x19d0 [i915]
    [    2.143026]  intel_display_driver_probe_noirq+0x42/0x240 [i915]
    [    2.143175]  i915_driver_probe+0x648/0xc50 [i915]
    [    2.143336]  i915_init+0x22/0xc0 [i915]
    [    2.143436]  ? __pfx_i915_init+0x10/0x10 [i915]
    [    2.143580] i915 0000:00:02.0: [drm] Port A asks to use VBT vswing/preemph tables
    [    2.143589] WARNING: CPU: 3 PID: 194 at drivers/gpu/drm/i915/display/intel_bios.c:2698 intel_bios_init+0xe78/0x19d0 [i915]
    [    2.143729] Modules linked in: i915(+) drm_buddy i2c_algo_bit drm_display_helper spi_pxa2xx_platform dw_dmac sd_mod cec dw_dmac_core rc_core spi_pxa2xx_core xhci_pci ttm ahci libahci xhci_hcd r8169 drm_kms_helper realtek usbcore libata mdio_devres crc32_pclmul drm scsi_mod crc32c_intel libphy i2c_i801 scsi_common i2c_smbus intel_lpss_pci intel_lpss idma64 usb_common fan video wmi pinctrl_alderlake button
    [    2.143747] RIP: 0010:intel_bios_init+0xe78/0x19d0 [i915]
    [    2.143895]  intel_display_driver_probe_noirq+0x42/0x240 [i915]
    [    2.144037]  i915_driver_probe+0x648/0xc50 [i915]
    [    2.144185]  i915_init+0x22/0xc0 [i915]
    [    2.144283]  ? __pfx_i915_init+0x10/0x10 [i915]
    [    2.144665] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+memFace-with-open-mouthwns=io+mem
    [    2.149343] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc.bin (v2.20)
    [    2.154808] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.36.0
    [    2.154815] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
    [    2.159426] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
    [    2.159933] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
    [    2.159935] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
    [    2.160270] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
    [    2.160971] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
    [    2.196030] [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 0
    [    2.238082] fbcon: i915drmfb (fb0) is primary device
    [    2.328251] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
    [    3.726439] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
    [    7.119905] i915 0000:00:02.0: [drm] Reducing the compressed framebuffer size. This may lead to less power savings than a non-reduced-size. Try to increase stolen memory size if available in BIOS.
    FFMPEG Logs:
    {"Protocol":0,"Id":"0b4ff1aac5e96437f5169f1454407d5c","Path":"/media/beelink/New Volume/TV Shows/Test Show/Season 01/testshowepisode01.mkv","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"mkv","Size":658259769,"Name":"testshowepisode01)","IsRemote":false,"ETag":"804bc27b345380b79db72b014961cd6a","RunTimeTicks":12870600000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"UseMostCompatibleTranscodingProfile":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"hevc","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"1080p HEVC SDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":4091556,"BitDepth":10,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"ReferenceFrameRate":23.976025,"Profile":"Main 10","Type":1,"AspectRatio":"16:9","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"aac","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Default","LocalizedForced":null,"LocalizedExternal":"External","LocalizedHearingImpaired":null,"DisplayTitle":"English - AAC - 5.1 - Default","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"5.1","BitRate":291535,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":"LC","Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"English - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":2,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"English - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":3,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":4383091,"FallbackMaxStreamingBitrate":null,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null,"HasSegments":false}
    /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -f matroska -init_hw_device vaapi=vaConfused-facedev/dri/renderD128,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -i file:"/media/beelink/New Volume/TV Shows/Test Show/Season 01/testshowepisode01.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 av1_qsv -preset veryfast -b:v 4091556 -maxrate 4091556 -bufsize 8183112 -profile:v:0 main -level 53 -g:v:0 72 -keyint_min:v:0 72 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(1920\,1080*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(1920/a\,1080))/2)*2,format=nv12" -codec:a:0 libfdk_aac -ac 2 -ab 256000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "439008315145422e3ce8f3314b3b20d5-1.mp4" -start_number 0 -hls_segment_filename "/var/cache/jellyfin/transcodes/439008315145422e3ce8f3314b3b20d5%d.mp4" -hls_playlist_type vod -hls_list_size 0 -y "/var/cache/jellyfin/transcodes/439008315145422e3ce8f3314b3b20d5.m3u8"
    ffmpeg version 7.1.1-Jellyfin Copyright © 2000-2025 the FFmpeg developers
      built with gcc 12 (Debian 12.2.0-14+deb12u1)
      configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto=auto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libharfbuzz --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-vaapi --enable-amf --enable-libvpl --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
      libavutil      59. 39.100 / 59. 39.100
      libavcodec    61. 19.101 / 61. 19.101
      libavformat    61.  7.100 / 61.  7.100
      libavdevice    61.  3.100 / 61.  3.100
      libavfilter    10.  4.100 / 10.  4.100
      libswscale      8.  3.100 /  8.  3.100
      libswresample  5.  3.100 /  5.  3.100
      libpostproc    58.  3.100 / 58.  3.100
    Input #0, matroska,webm, from 'fileConfused-facemedia/beelink/New Volume/TV Shows/Test Show/Season 01/testshowepisode01.mkv':
      Metadata:
        encoder        : libebml v1.3.5 + libmatroska v1.4.8
        creation_time  : 2020-09-25T20:39:35.000000Z
        Writing frontend: StaxRip v1.7.0.6
      Duration: 00:21:27.06, start: 0.000000, bitrate: 4091 kb/s
      Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn (default)
          Metadata:
            BPS            : 3797370
            BPS-eng        : 3797370
            DURATION        : 00:21:26.994000000
            DURATION-eng    : 00:21:26.994000000
            NUMBER_OF_FRAMES: 30857
            NUMBER_OF_FRAMES-eng: 30857
            NUMBER_OF_BYTES : 610899136
            NUMBER_OF_BYTES-eng: 610899136
            _STATISTICS_WRITING_APP: mkvmerge v20.0.0 ('I Am The Sun') 64-bit
            _STATISTICS_WRITING_APP-eng: mkvmerge v20.0.0 ('I Am The Sun') 64-bit
            _STATISTICS_WRITING_DATE_UTC: 2020-09-25 20:39:35
            _STATISTICS_WRITING_DATE_UTC-eng: 2020-09-25 20:39:35
            _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      Stream #0:1(eng): Audio: aac (LC), 48000 Hz, 5.1, fltp (default)
          Metadata:
            BPS            : 291535
            BPS-eng        : 291535
            DURATION        : 00:21:27.040000000
            DURATION-eng    : 00:21:27.040000000
            NUMBER_OF_FRAMES: 60330
            NUMBER_OF_FRAMES-eng: 60330
            NUMBER_OF_BYTES : 46902212
            NUMBER_OF_BYTES-eng: 46902212
      Stream #0:2(eng): Subtitle: subrip (srt)
          Metadata:
            BPS            : 110
            BPS-eng        : 110
            DURATION        : 00:20:55.298000000
            DURATION-eng    : 00:20:55.298000000
            NUMBER_OF_FRAMES: 566
            NUMBER_OF_FRAMES-eng: 566
            NUMBER_OF_BYTES : 17372
            NUMBER_OF_BYTES-eng: 17372
      Stream #0:3(eng): Subtitle: subrip (srt)
          Metadata:
            BPS            : 116
            BPS-eng        : 116
            DURATION        : 00:21:17.102000000
            DURATION-eng    : 00:21:17.102000000
            NUMBER_OF_FRAMES: 607
            NUMBER_OF_FRAMES-eng: 607
            NUMBER_OF_BYTES : 18618
            NUMBER_OF_BYTES-eng: 18618
    Stream mapping:
      Stream #0:0 -> #0:0 (hevc (native) -> av1 (av1_qsv))
      Stream #0:1 -> #0:1 (aac (native) -> aac (libfdk_aac))
    [av1_qsv @ 0x5650b38e3440] Current profile is unsupported
    [av1_qsv @ 0x5650b38e3440] Selected ratecontrol mode is unsupported
    [av1_qsv @ 0x5650b38e3440] Current frame rate is unsupported
    [av1_qsv @ 0x5650b38e3440] Current picture structure is unsupported
    [av1_qsv @ 0x5650b38e3440] Current resolution is unsupported
    [av1_qsv @ 0x5650b38e3440] Current pixel format is unsupported
    [av1_qsv @ 0x5650b38e3440] some encoding parameters are not supported by the QSV runtime. Please double check the input parameters.
    [vost#0:0/av1_qsv @ 0x5650b38ef580] Error while opening encoder - maybe incorrect parameters such as bit_rate, rate, width or height.
    [vf#0:0 @ 0x5650b3584000] Error sending frames to consumers: Function not implemented
    [vf#0:0 @ 0x5650b3584000] Task finished with error code: -38 (Function not implemented)
    [vf#0:0 @ 0x5650b3584000] Terminating thread with return code -38 (Function not implemented)
    [vost#0:0/av1_qsv @ 0x5650b38ef580] Could not open encoder before EOF
    [vost#0:0/av1_qsv @ 0x5650b38ef580] Task finished with error code: -22 (Invalid argument)
    [vost#0:0/av1_qsv @ 0x5650b38ef580] Terminating thread with return code -22 (Invalid argument)
    [out#0/hls @ 0x5650b38e6dc0] Nothing was written into output file, because at least one of its streams received no packets.
    frame=    0 fps=0.0 q=0.0 Lsize=      0KiB time=N/A bitrate=N/A speed=N/A
    Conversion failed!
    2025-07-26, 06:03 PM
    (2025-07-26, 05:35 PM)Unstirred6783 Wrote: Stream mapping:
    Your processor does not support Encoding in AV1, turn that off.
    Unstirred6783
    2025-07-26, 06:42 PM
    This fixed it! Thank you so much Smiling-face
