    Jellyfin Forum Support Troubleshooting Networking & Access Hardware Encoding problem
    Pages (3): 1 2 3 Next »
    Im using Alpine Docker with portainer and Compose v2
    Parz1val
    Country:Denmark
    2024-06-18, 06:30 PM (This post was last modified: 2024-06-18, 06:32 PM by Parz1val. Edited 1 time in total.)
    Whello, i am trying to host Jellyfin image from linuxserver on alpine docker with portainer from proxmox helper scripts. I am using linuxserver because thats what im using on my unraid server but im migrating from that, so i thought it would be easier to just copy all files over, which i did. Now all is working except hardware encoding. My jellyfin version is 10.9.6. I have posted my logs from portainer
    These are my settings for encoding:
    https://imgur.com/a/59vFdsn
    I am using a Intel® Core™ i7-6700 Processor https://ark.intel.com/content/www/us/en/...0-ghz.html
    I have tried installing a fresh image from jellyfin instead but the problem still persist. (I have used the fresh image to test, because it was the same error, and i didn't want to mess with the one were i already moved my settings, because it took a long time to figure out how to do that)
    But i think i know the problem but dont know how to fix it and that is jellyfin-ffmpeg is missing at /usr/lib/jellyfin-ffmpeg/ffmpeg which is what is specified in settings
    There just isn't a folder called jellyfin-ffmpeg
    And i have made passthrough from my proxmox host and im pretty sure its setup correctly. I dont know what screenshots or settings you might else need to see (Im new to this sort of thing, i always find my solution in another post) So write if you want to see something else and i will happily screenshot it/write the command.
    my media folder is still on the unraid server and is connected through nfs share. And jellyfin will play the movies/shows if i disable hardware acceleration aka set it to none
    Maybe you also need this, idk
    https://imgur.com/a/Qyrtrl3
    .txt   _Jellyfin-test_logs.txt (Size: 18.15 KB / Downloads: 107)
    2024-06-18, 06:35 PM
    Can you share the ffmpeg log? Those are in the same folder as the log you attached.
    Looks at steps 4 and 5 from this section of our Intel docs.
    https://jellyfin.org/docs/general/admini...ial-docker
    They will help validate that the docker has sufficient access to the iGPU.
    Also, are you running docker in a LXC/VM? Or directly on proxmox/debian?
    Parz1val
    Country:Denmark
    2024-06-18, 06:43 PM
    (2024-06-18, 06:35 PM)TheDreadPirate Wrote: Can you share the ffmpeg log?  Those are in the same folder as the log you attached.
    This is what happens when i check if it has access
    https://imgur.com/a/X8okGh6
    "Also, are you running docker in a LXC/VM?  Or directly on proxmox/debian?"
    I am running it in an LXC with Alpine docker, portainer and docker compose v2, its a container from tteck helper scripts/proxmox helper scripts
    So to clarify it is running on portainer https://imgur.com/a/Z4ulA86
    2024-06-18, 07:55 PM
    How did you do the GPU passthrough into the LXC?
    https://forum.proxmox.com/threads/guide-...xc.142639/
    Skip down to "Set up the Intel iGPU passthrough using QSV". Is that what you did? In the LXC can you see the GPU?
    sudo ls -l /dev/dri
    Parz1val
    Country:Denmark
    2024-06-18, 07:57 PM (This post was last modified: 2024-06-18, 07:59 PM by Parz1val.)
    I just noticed i didn't share the ffmpeg, but i have alot of those logs, which one do you need/want?
    https://imgur.com/a/n9Nnp4F
    (2024-06-18, 07:55 PM)TheDreadPirate Wrote: How did you do the GPU passthrough into the LXC?
    sudo ls -l /dev/dri
    https://imgur.com/a/kdSZ6uO
    Yes it can see the GPU after what i can see, but i will check the guide
    Parz1val
    Country:Denmark
    2024-06-18, 08:05 PM (This post was last modified: 2024-06-18, 08:06 PM by Parz1val. Edited 1 time in total.)
    sudo ls -l /dev/dri
    The container is running as privileged, so i followed a guide i found on github
    https://imgur.com/a/5j0qICw
    https://github.com/jellyfin/jellyfin.org/issues/982
    2024-06-18, 08:08 PM
    And how are you passing the iGPU into the jellyfin container?
    Parz1val
    Country:Denmark
    2024-06-18, 08:12 PM
    (2024-06-18, 08:08 PM)TheDreadPirate Wrote: And how are you passing the iGPU into the jellyfin container?
    I am passing the group id's to the jellyfin container here:
    https://imgur.com/a/9Ya0gft
    and then im also adding the drive here:
    https://imgur.com/a/Il2Cx9k
    I have tried both /dev/dri/ and /dev/dri/RenderD128
    2024-06-18, 08:33 PM (This post was last modified: 2024-06-18, 08:34 PM by TheDreadPirate. Edited 1 time in total.)
    (2024-06-18, 07:57 PM)Parz1val Wrote: I just noticed i didn't share the ffmpeg, but i have alot of those logs, which one do you need/want?
    I want the ffmpeg_transcode logs.
    Also, do you have IOMMU enabled in your BIOS?
    Parz1val
    Country:Denmark
    2024-06-18, 08:45 PM
    I got you two different logs, tell me if you need more
    Im not sure if i have that enabled in my BIOS. I will check tommorow
    .txt   FFmpeg.Transcode-2024-06-18_17-33-12_758ca1bdb4c492ae9401e1761b59b8c8_191c870e.txt (Size: 8.55 KB / Downloads: 122)
    .txt   FFmpeg.Transcode-2024-06-18_17-34-46_758ca1bdb4c492ae9401e1761b59b8c8_33e5f6df.txt (Size: 8.55 KB / Downloads: 104)
