2024-04-16, 01:34 PM
Hello dear Jellyfin community!
I have Jellyfin running on a mini PC at my home and am mostly using it to watch movies on my TV via the Jellyfin app on my Google Chromecast TV. Every once in a while I access it remotely to watch something on my tablet when I am away from home.
I am getting a lot of "This client isn't compatible with the media and the server isn't sending a compatible media format" errors and really have no idea how to approach this problem.
My current suspicion is that I need to setup HW transcoding properly.
Here some data:
I am running headless Ubuntu 22.04.4 LTS (GNU/Linux 5.15.0-102-generic x86_64) and have Jellyfin running in its own container managed via Portainer.
Why the difference between Intel® Core i5-4590T CPU and Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics? (lshw -C display vs lshw -C cpu)
When I read about "Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics" it says there is no GPU or iGPU. When I read about "Intel® Core i5-4590T CPU" it says that there is a Intel® HD Graphics 4600?
And also what would be the best settings for HW transcoding? I currently have it set to None...
How do I have to spin up my container, so that Docker has access to whatever it needs to be able to run the HW transcoding?
Thank you!
Here some data:
sudo lshw -C display
*-display
description: VGA compatible controller
product: Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:29 memory:f7800000-f7bfffff memory:e0000000-efffffff ioport:f000(size=64) memory:c0000-dffffCode:
sudo lshw -C cpu
*-cpu
description: CPU
product: Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
vendor: Intel Corp.
physical id: 40
bus info: cpu@0
version: 6.60.3
slot: SOCKET 0
capacity: 3800MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid xsaveopt dtherm ida arat pln pts md_clear flush_l1d cpufreq
configuration: cores=4 enabledcores=4 microcode=40 threads=4Why the difference between Intel® Core i5-4590T CPU and Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics? (lshw -C display vs lshw -C cpu)
Thank you!
