    Jellyfin Forum Support Troubleshooting HDR to SDR Tone Mapping doesn't work
    HDR to SDR Tone Mapping doesn't work - image still washed out
    mariod12345
    Country:Croatia
    2024-04-02, 08:59 PM
    Hello everyone,
    I have a 4K HDR10 movie on my Jellyfin Server Version 10.8.13 and when I tried to play it on 4K NON-HDR Toshiba Television on Firestick 4K MAX Jellyfin client, the image is still washed out in Exoplayer and in LibVLC.
    Enabling and disabling tone mapping doesn't affect anything.
    Specs:
    Processor: Intel Core i7-7700T CPU @ 2.90GHz  2.90 GHz
    Installed RAM 32,0 GB (31,8 GB usable)
    GPU: Intel HD Graphics 630 (Driver version 31.0.101.2127)
    OS:
    Edition Windows 11 Pro
    Version 22H2
    OS build 22621.3296
    Experience Windows Feature Experience Pack 1000.22687.1000.0
    2024-04-02, 09:03 PM
    Tone mapping on the server would only happen if it is transcoding. It sounds like the client isn't requesting a transcode. Are you able to verify that either in the logs or by showing the playback info in the client?
    mariod12345
    Country:Croatia
    2024-04-02, 09:26 PM
    Thanks for the answer TheDreadPirate!
    I managed it to work if I set bitrate to 10Mbit/s or lower. This triggers to transcode and get the right colors. I don't know how to use logs but I see in task manager when transcoding starts.
    Is there any other way to force tone mapping? Is this problem with Android TV client or Jellyfin server?
    Thanks!
    2024-04-02, 10:05 PM
    I'm not sure if the problem is Jellyfin on Android TV or FireOS. Since you have a 4K HDR capable Firestick on a non-HDR 4K TV. I'm not sure which component is responsible for the issue. My understanding is that Jellyfin asks the OS about the connected TV's capabilities.
