    Jellyfin Forum Support General Questions Help with authentication provided by reverse proxy
    jose1711
    Country:Slovakia
    2024-11-03, 08:49 PM
    following https://blog.sjain.dev/caddy-sso/ I started to migrate my services behind Caddy reverse proxy with a SSO configured. For Jellyfin I did something like this (Caddyfile):
      security {
            authorization policy admin_policy {
              set auth url https://portal.mydomain.com
              allow roles authp/admin
    jellyfin.mydomain.com {
      authorize with admin_policy
      reverse_proxy http://localhost:8096
    When accessing https://jellyfin.mydomain.com I am redirected to https://portal.mydomain.com where I am queried for credentials (configured inside Caddy's local store) and once validated I am redirected back and presented with Jellyfin login window. Here I need to log in once more.
    Is there a way to tell Jellyfin - that a user foo is a valid user and his/her identity has been proven already? I saw several questions floating on the forums/github but could not find a definitive answer whether this is supported or not.
    Thanks, j
    crobibero
    Core Team (Server & Plugins)
    2024-11-04, 05:02 AM
    You would need to use something like the SSO plugin. https://github.com/9p4/jellyfin-plugin-sso
    jose1711
    Country:Slovakia
    2024-11-05, 01:30 PM
    This would be too much, I am looking for a header authentication but it seems this is not yet supported (as per https://features.jellyfin.org/posts/471/...entication)
    jose1711
    Country:Slovakia
    2024-11-09, 12:09 PM
    Eventually I used Caddy with Authelia (https://www.authelia.com/integration/ope.../jellyfin/) and SSO plugin you mentioned.
    Duvel
    Country:Belgium
    2025-03-19, 09:41 AM (This post was last modified: 2025-03-19, 09:43 AM by Duvel. Edited 1 time in total.)
    (2024-11-05, 01:30 PM)jose1711 Wrote: This would be too much, I am looking for a header authentication but it seems this is not yet supported (as per https://features.jellyfin.org/posts/471/...entication)
    @TheDreadPirate could you share a bit of info about Proxy Header Authentication feature?
    Is it currently even considered by the team? If yes, any ETA ??? if no, why??
    My current setup (like many) is LDAP plugin + Authentik. And I use caddy for the reverse proxy. Mostly all my exposed services work with a single login page (Authentik) and then the user straight connect automatically on everything (including user creation). Only for Jellyfin Web my users have to login twice : once in Authentik and once in Jellyfin. Thats really annoying.
    niels
    Core Team
    Country:Netherlands
    2025-03-19, 10:16 AM
    No there are no plans to support custom headers for authorization as this is unlikely to work with our native clients.
    [Image: GitHub%20Sponsors-grey?logo=github] [Image: Buy%20Me%20a%20Coffee-grey?logo=buymeacoffee]
    evan314159
    2025-07-10, 02:59 PM
    You can install Tailscale on your devices including TV and then Tailscale would provide authentication automatically instead of the user entering a password. The missing bit is proxy header authentication.
