    Jellyfin Forum Support Troubleshooting Help with orphaned data in logs after changing paths
    Drake97
    Threads: 26
    Country:Chile
    2025-09-09, 06:02 AM
    I kindly ask for your help.
    Previously, all my libraries had very long and redundant paths, so I shortened them and everything was fine. However, when I checked the logs, I found a lot of spam from the previous data.
    I tried running a couple of commands that chat gpt gave me, but nothing happens, I still get this:
    https://pastebin.com/ECba394E
    [Image: imagen.png]
    Do you know how I can get this “cleaned up” so I can review my logs more calmly for other errors?
    What I think is that I basically i screw up my jellyfin.
    Thanks in advance.
    Jellyfin 10.10.7
    Ubuntu desktop 24.04.3 LTS
    Intel i3-12100
    16GB DDR4 2400Mhz
    OS-DRIVE: WDC SN720 256GB
    Storage (JF Library)
    1: x4 4TB Seagate IronWolf
    2: 6TB Seagate Ironwolf Pro
    3: 8TB HGST Dell Enterprise
    4: 2TB Seagate Barracuda
    5: 2TB WD RED
    Drake97
    Threads: 26
    Country:Chile
    2025-09-09, 06:13 AM
    What happened, looking back now, is that when I deleted the routes, everything went wrong, and I can't even add folders to the library.
    However, when I play a movie, it plays, but I can't add anything else.
    Did Jellyfin have some kind of automatic backup, or do I have to resign myself to restoring everything? Or maybe install Jellyfin again :c
    Jellyfin 10.10.7
    Intel i3-12100
    16GB DDR4 2400Mhz
    5: 2TB WD RED
    2025-09-09, 04:30 PM
    I would first try removing the library, then re-adding it. Jellyfin will retain the metadata. No, there's no auto backup in 10.10.x. That's up to you.
    Drake97
    Threads: 26
    Country:Chile
    2025-09-10, 03:41 AM
    (2025-09-09, 04:30 PM)theguymadmax Wrote: I would first try removing the library, then re-adding it. Jellyfin will retain the metadata. No, there's no auto backup in 10.10.x. That's up to you.
    In the end I had to recreate the missing folders, because I accidentally deleted them:
    sudo mkdir -p /var/lib/jellyfin/root/default
    sudo mkdir -p /var/lib/jellyfin/metadata
    sudo chown -R jellyfin:jellyfin /var/lib/jellyfin
    sudo chmod -R 755 /var/lib/jellyfin
    The downside is that I had to add my whole library again (almost 2,000 movies), rescan everything, and now I’m regenerating the trickplay images.
    Can you please confirm if those permissions look right for Jellyfin on Ubuntu? Also, do trickplay images only get stored under
    /var/lib/jellyfin/metadata, or does Jellyfin save them somewhere else too?
    Thanks a lot!
    Jellyfin 10.10.7
    Intel i3-12100
    16GB DDR4 2400Mhz
    5: 2TB WD RED
    2025-09-11, 02:22 AM
    Thanks a lot!
    I meant remove the library from within Jellyfin itself not the filesystem. That all seems correct.
    Trickplays in 10.10.7 are stored:
    Config -> metadata -> library -> (two letters) -> (id) -> trickplay
    In 10.10.11:
    Config -> data -> trickplay -> (two letters) -> (id
