    Jellyfin Forum Support General Questions How do I know if I am watching Dolby Vision, Atmos, DTS, TrueHD, HDR10+ etc?
    Keith
    2023-10-06, 12:17 AM
    Hi all, am a newbie here. My Jellyfin set up is my PC is my server and I have clients installed on my TV and mobile.I see my content has the DTS, Dolby Atmos/vision stuff but how do I know I am experiencing this? Is there a way to check?
    Am asking this because I don't understand how these work together and how to check what format it's playing.
    If my TV model supports Dolby Vision, can I assume it will play all Dolby Vision content without any tweaking?
    Similarly, if my soundbar supports Atmos but not DTS, it can play Atmos content but if I choose DTS, it will not play any sound or will DTS option not even be available when I am watching the content.
    Thanks!
    2023-10-06, 12:46 AM
    Most clients will have a playback info option that looks like a little information icon or straight up says playback info. This will tell you whether it's direct play or transcoding, video and audio codec, and container. You'll also generally get limited additional information such as dynamic range (HDR/10/10+/DV) but no detailed info *most of the time*. The web clients tend to be the most verbose here (those that use the web player) and provide info like profile and level for the codec (but not DolbyVision).
    For Atmos...honestly, you can tell. I'm pretty deaf and I can tell immediately when it's Atmos versus any other type of audio. And for audio tracks, if you have transcoding enabled on your server and for your particular user, selecting an incompatible track will trigger transcoding, meaning your server will convert the incompatible audio (or video in many cases) to a compatible codec on the fly. It's best to avoid this when possible but it's the whole reason Jellyfin exists; it's not always possible to avoid this scenario.
    Dex Luther
    2023-10-06, 05:58 AM
    Example of the playback info:
    [Image: UQwLojI.png]
