    Jellyfin Forum Support General Questions How to Integrate Basic Sensor Monitoring in Jellyfin Dashboard?
    Aria James
    Country:Bolivia
    2025-07-26, 11:04 AM
    Hi everyone! I’m experimenting with ways to integrate some basic hardware stats or room environment feedback (like temperature or proximity) into a Jellyfin dashboard widget just for fun and to learn more about home automation. While testing with sensors like the HC-SR04 ultrasonic module, I followed this helpful article on how it works with Arduino:
    https://www.theengineeringprojects.com/2...ensor.html
    My idea is to use an API or plugin to show simple status like user approaching or room occupied on Jellyfin. I saw similar ideas discussed on Home Assistant forums and also looked at Jellyfin API docs, but I’m not sure where to start for integrating basic external inputs.
    crobibero
    Core Team (Server & Plugins)
    2025-07-26, 01:22 PM
    Jellyfin doesn’t support providing custom metrics that would be displayed anywhere. I would think that you would send the metrics to home assistant?
