2025-03-16, 02:57 AM
I installed a new SSD on my computer a while back and hadn’t used Jellyfin since I installed it. I put all my media on an external 2tb hhd via usb 3.0, it seems it used to be assigned F: but is now assigned D: I’m not qiute sure how or why that happaned but whenever I try to add a library from the external hard drive Jellyfin either doesn’t recognize the address or doesn’t have access to the drive. My torrenting program had issues writing to the drive as well so I downloaded to my computers SSD directly and just moved the files to the hard drive manually afterwards. I edited the properties of the hard drive to make the security as open as possible but it didn’t seem to make a difference. I can’t watch any of my media on Jellyfin because it all still has file paths with the F: prefix which is not in use by my drive anymore. Should I move the media off the drive and try reformatting it and then put the media back? I’m at a loss how to troubleshoot this at this point.
(OS is windows 11)
(OS is windows 11)
