    Jellyfin Forum Support Troubleshooting Jellyfin for Kodi sync problem
    GrosJambon33
    2025-05-17, 09:43 AM (This post was last modified: 2025-05-17, 09:44 AM by GrosJambon33. Edited 1 time in total.)
    Hello guys,
    i've installed Jellyfin in a docker container (Homelab on Debian 12.1) and it is working flawlessly so far.
    i've also set up a Rpi 4b with LibreELEC and the Jellyfin for Kodi add-on. I can play content without any issues.
    But the thing is that after the add-on is connected to the Jellyfin server (after each boot up of the raspberry), the librairies on LibreELEC are not updated with the latest media i put on the server. I need to go to addon settings to manually update librairies to get the last medias.
    I'm on LibreELEC 12.0.2 and the jellyfin addon is on 1.07+py3
    Kody Sync Queue is installed on the server side.
    Thanks in advance for your help and do not hesitate if you need further informations.
    Regards,
    GrosJambon33
    2025-05-23, 09:57 PM (This post was last modified: 2025-05-23, 09:58 PM by GrosJambon33.)
    Any help on this ?
    Thanks in advance
    GrosJambon33
    2025-06-02, 09:35 AM
    HEllo,
    If anyone has an idea on this, i'm still interested Smiling-face
    thanks
    KodiUser1138
    Threads: 35
    2025-06-02, 11:32 AM
    Just checking my post t osee if there was any advice here at 6am and saw your request. Off the top of my half-asleep mind I know there is plugin for Jellyfin for Kodi to sync and I'm pretty sure a setting to auto push the updates. But I use Windows Kodi clients not Pi so not sure how similar it may be. But it does work and it is awesome!
    JF Wish List:
    IMDb Top250 metadata
    Collection content rules: Library-Title/Sorttitle/Tag/Director/Filename/Contains
    Collection organized by Library
    Media info show added Collection
    Soundtrack auto link to movie by title/sort/Manual
    Read Music Album Sort
    Nousemusic
    2025-06-03, 05:55 AM (This post was last modified: 2025-06-03, 08:42 AM by Nousemusic. Edited 1 time in total.)
    Good morning,
    I have the same problem. Kodi Sync Que is installed in version 14.0.0.0 on the Jellyfin server. Everything went smoothly. Since a few days Kodi (LibreELEC) has the problem that it no longer loads library content updates on startup. If I shut down the Pi and start it up again, it sometimes works again. I have not made any changes to the settings. The behavior occurs on several devices.
    Jellyfin runs on the following version:
    server version
    10.10.7
    Web version
    10.10.7 (f4b8aa0ed)
    Build version
    10.10.7
    Does anyone have an idea?
    Thanks & best regards
    GrosJambon33
    2025-07-10, 06:49 PM
    I've reinstalled Libreelec from scratch on my Pi4 but still have the problem. I need to manually refresh libraries to get latest medias.
    is this a known problem ?
    kandykarter
    Threads: 22
    2025-07-11, 01:28 PM
    Silly question, but you also have Kodi Sync Queue enabled in the Kodi addon?
    Specifics:
    Jellyfin 10.11.2 (docker) on Debian 12.6 // N100 16GB
    Storage: Synology DS220+ CIFS mounts
    Clients: Jellyfin4Kodi & Jellycon, Android, Android TV, Roku
