    Jellyfin Forum Support Troubleshooting Jellyfin on docker won't restart after power failure
    SquishySquash
    Threads: 8
    Country:Poland
    2025-06-28, 06:47 PM (This post was last modified: 2025-06-28, 06:51 PM by SquishySquash. Edited 2 times in total.)
    I'm running Jellyfin on my Synology NAS server using Container Manager.
    I'm using official jellyfin/jellyfin image from https://hub.docker.com/r/jellyfin/jellyfin
    My YAML compose is:
        image: jellyfin/jellyfin:latest
        container_name: jellyfin
        network_mode: host
        environment:
          - TZ=Europe/Warsaw
          - /volume2/docker/jellyfin/config:/config
          - /volume2/docker/jellyfin/cache:/cache
          - /volume2/docker/jellyfin/logs:/logs
          - /volume1/Data/Media:/media
        devices:
    #      - /dev/dri/renderD128:/dev/dri/renderD128
          - /dev/dri:/dev/dri
        restart: 'unless-stopped'
    My NAS is configured to automatically restart after power failure and it does so, the problem is that when there is power failure and my NAS reboots once power is back on the Jellyfin container wont restart automatically.
    Beside Jellyfin I'm also running other services in containers and most of them restart after power failure without any problems (despite using same restart:'unless-stopped' config). Jellyfin is one of few that causes problems.
    In case i simply turn off my NAS and turn it back on (using physical button) then all containers restart without issues.
    2025-06-28, 07:33 PM
    Can you post the Jellyfin server logs.
    SquishySquash
    Threads: 8
    Country:Poland
    2025-06-29, 05:57 PM (This post was last modified: 2025-06-29, 05:58 PM by SquishySquash. Edited 1 time in total.)
    (2025-06-28, 07:33 PM)theguymadmax Wrote: Can you post the Jellyfin server logs.
    There is nothing in jellyfin logs.
    There is simply a time gap. Last entries are from whatever hour I've accessed Jellyfinn last time and then next log entry will be from the moment I manually start jellyfin container on my NAS
    The problem is with whole jellyfin container/image not jellyfin service.
    gears
    2025-07-01, 06:17 PM
    Try adding restart: 'unless-stopped' to your docker compose.
    For example:
        network_mode: host
