    Jellyfin Forum Support General Questions Jellyfin Solve My Problem?
    ChaoscripT
    Country:Israel
    2025-09-23, 10:12 AM (This post was last modified: 2025-09-23, 10:12 AM by ChaoscripT. Edited 1 time in total.)
    Hi,
    I don't know if "Problem" is the right word, but here is my situation.
    I have NVIDIA Shield Pro streamer that connect to it via USB SSD with some local content (TV Shows/Movies), to run these I use VLC Player.
    I also have IPTV (m3u8 URL) that I use Televizo app to run this.
    My question is if I can "connect" between them and run in one app and more nicely GUI?
    Regards.
    conor
    2025-09-23, 12:41 PM
    You could use Jellyfin but you'd need a server of some sorts to run it on (something simple like a Raspberry pi would do).
    For what you've described Kodi would be a simpler solution. It's available in the play store and combined with the IPTV Simple Client addon will do what you want.
    Kodi is an excellent media player but there is a learning curve to it and you'll need to hide a lot of stuff in the UI to make it look clean.
    ChaoscripT
    Country:Israel
    2025-09-23, 03:22 PM
    (2025-09-23, 12:41 PM)conor Wrote: You could use Jellyfin but you'd need a server of some sorts to run it on (something simple like a Raspberry pi would do).
    Thanks for reply,
    I can't install server on the NVIDIA and also the user?
    From what I read, Kodi's IPTV add on don't handle good the IPTV, so I thought maybe Jellyfin will works good with that.
    regards.
