    Jellyfin Forum Support General Questions Jellyfin Synology without Docker
    bouguie
    2023-10-25, 08:51 AM
    Hi:
    I have
    NAS SYNOLOGY DS214Play
    OS: DSM 7.1
    CPU: Intel Atom Doble núcleo 1,6 GHz
    Memory:  DDR3 1 GB
    In previous versions there was a package to download with Jellyfin, but I can't find the package for this version of the operating system (DSM 7.1).
    Does anyone have or know where I can download the package for this version?
    This NAS model does not have Docker support.
    Thank You
    2023-10-25, 12:37 PM
    If it isn't available in their package repo, your unit may not be supported. The CPU is quite old and 1GB of RAM is definitely not sufficient for a good Jellyfin experience.
    It would be better to run Jellyfin on an old PC and use your NAS for storage.
    bouguie
    2023-10-25, 01:09 PM
    Thank You TheDreadPirate.
    I have had Plex and Emby on that NAS and they worked well, that's why I thought it was also possible with Jellyfin.
