    Jellyfin Forum Support General Questions Loading GLSL shaders and using mpv.input without MPV Shim?
    Not able to get the config etc to work
    meowk
    2025-03-24, 04:57 PM
    Hey, i'm trying to get glsl shaders to work with jellyfin media player, unfortunately my config doesn't seem to work at all no matter what i try, at the same time, i don't know how to use mpv.input neither. It seems possible with mpv shim, however if possible i'd rather just use the default app
    meowk
    2025-03-26, 03:07 AM (This post was last modified: 2025-03-26, 03:09 AM by meowk. Edited 1 time in total.)
    I'm also struggling with getting GLSL-Shaders to work on Android TV. As far as I've seen, Android TV paths are the exact same as regular Android, however even with my MPV config set up the same as someone with a regular Android, I can't get it working on my Nvidia Shield (Everything else in the config seems to work but it just won't load the shaders for some odd reason) though this is a problem with MPV not Jellyfin (Though I plan on using MPV as an external player on Jellyfin if I ever get it working)
