    Jellyfin Forum Support General Questions Low Power Jellyfin Server
    The Cookie Gangster
    2023-12-17, 06:26 PM
    Good evening everyone.
    Fairly new to the media server world, recently discovered and now throughly hooked and intrigued by the possibilities of starting and building my own extensive media library using Jellyfin.
    Bought parts intended to go towards a "server"
    CPU: Ryzen 5 5600G
    Motherboard:Asus A520M plus Wi-Fi
    PSU: Corsair RM650
    RAM: 16Gb  3200 corsair
    Storage: 2 4TB Ironwolf HDD
    Would there be any way to reconfigure the hardware into a low power server? I.e add new parts in order to achieve this?
    Venson
    Threads: 8
    2023-12-17, 06:52 PM
    well i would ask what constitutes as "low power" for you?
    Jellyfin 10.12.0 release will be Soon™
    [Image: default-yellow.png]
    2023-12-17, 07:15 PM (This post was last modified: 2023-12-17, 07:16 PM by TheDreadPirate. Edited 1 time in total.)
    In your BIOS you can disable turbo states and high performance modes. Those consume A LOT more power for not a lot of performance gain. And those gains are even less significant for a jellyfin setup.
    The Cookie Gangster
    2023-12-17, 08:46 PM (This post was last modified: 2023-12-17, 08:47 PM by The Cookie Gangster.)
    (2023-12-17, 06:26 PM)The Cookie Gangster Wrote: Good evening everyone.
    CPU: Ryzen 5 5600G
    PSU: Corsair RM650
    (2023-12-17, 06:52 PM)Venson Wrote: well i would ask what constitutes as "low power" for you?
    20 Watts realistic?
    (2023-12-17, 07:15 PM)TheDreadPirate Wrote: In your BIOS you can disable turbo states and high performance modes.  Those consume A LOT more power for not a lot of performance gain.  And those gains are even less significant for a jellyfin setup.
    Thanks, is your system always on and how much power does it draw?
    2023-12-17, 08:57 PM
    My system is always on. I haven't measured, but I'd estimate that it draws 25-30W idle. A lot of that is just the 3 hard drives.
    Typical power draw when loaded (transcoding) is around 60W for short periods of time.
