    Jellyfin Forum Support Troubleshooting Merge Versions - Split all movies does not work
    Problems with the Plugin "Merge Versions"
    Celvin238
    2024-12-29, 08:43 PM
    Hello Jellyfin-Support,
    I wanted to try out the plugin "Merge Versions" (10.9.1.1) with Jellyfin 10.10.3 running on docker on a Synology DS224+.
    Unfortunately I then realized it is not ideal for my system.
    That's why I wanted to undo the function. To do this there is an option called “Split All Movies” in the plugins settings. If I activate this function, the message "Spitting Movies" appears briefly, but the movies remain merged... Weary-face
    Hopefully you can help me...
    Thanks in advance!
    Celvin
    Celvin238
    2024-12-29, 09:36 PM
    Oh, I have also installed the plugin "TMDb Box Sets"... maybe that is the problem. How can remove this "box sets"?
    Celvin238
    2024-12-29, 09:41 PM
    The answer is here: https://forum.jellyfin.org/t-managing-collections (#5)
