    Jellyfin Forum Support General Questions metadata and subtitles problems
    having trouble with metadata and subtitles
    Spencer1
    2025-01-26, 10:45 AM
    hi, so my friend helped me set up a jellyfin server, but I have zero knowledge about computers and coding and stuff.
    I have been having trouble with the metadata for some shows, even after I use identify and enter the imbd id it doesn't work, I also tried manually adding the title and more information, but it cannot find it.
    (I also have an imbd plugin, if that is relevant)
    I'd appreciate help that is "dumbed-down" because I tried searching and reading the forums but I cannot understand a thing.
    I also would appreciate help regarding a way to sync my subtitles, although I have even less understanding and information about it, so I get it might be hard to help me with that.
    2025-01-26, 01:36 PM
    (2025-01-26, 10:45 AM)Spencer1 Wrote: I have zero knowledge about computers and coding and stuff.
    YouTube has plenty of tutorials on computers, ranging from basic skills to coding. If you're interested in learning, consider taking a class.
    Quote:I have been having trouble with the metadata for some shows, even after I use identify and enter the imbd id it doesn't work, I also tried manually adding the title and more information, but it cannot find it.
    Read the documents here on how to name you file and folders.
    You can try subsyncarr or manually sync your files with Subtitle Edit.
