    Jellyfin Forum Development Client Development Kodi Development Movies do not appear on CoreELEC Nightly starting 20240109 cont.
    tmsrxzar
    2024-01-10, 02:43 PM (This post was last modified: 2024-01-10, 03:19 PM by tmsrxzar. Edited 1 time in total.)
    Continuation from https://forum.jellyfin.org/t-hdr-info-pa...1#pid13111
    More or less for documentation purposes, pretty sure the issue is with Kodi itself
    last thing i checked were the comparisons between MyVideos128 and MyVideos129
    something failed to transfer over internally on Kodi when it upgraded that database version
    the videoversion and videoversiontype tables are empty on the second but present in the first and the jellyfin addon isn't even aware of that table currently so no way it modified it
    result "movie_view" in the kodi db does not return any records on 129 but still works in 128
    kodi uses that view to display anything in it's ui so nothing gets displayed
    expect this to be fixed in kodi upstream, for now as a hack workaround 129 has been replaced with 128 but no idea what the full scope or long term affects are
    edit:
    found a better fix
    simply removing the MyVideos129 (while MyVideos128 is still present and kodi is stopped from systemctl) then starting kodi again
    kodi has redone it's 128->129 migration and it seems to be working fine again
    Adam86
    2024-01-12, 03:21 PM
    Thanks for having a quick look at this.
    I had a quick go at the workaround you listed, & it did appear to work, although no new Movies seemed to be getting picked up and added for me afterwards.  So still think something "odd" is going on.
    Removed both old and new DB and then Movies was empty again just as before.
    Lets just hope it's a bug thats been caused for now.
    mcarlton00
    Kodi Addon Maintainer
    2024-01-13, 01:46 PM
    Still haven't found any better way to get a nightly running on my main dev workstation. I was able to get Kodi 21-beta2 working by going through flatpak, but still haven't been able to successfully build nightly. So I can now confirm that things are working as expected in beta2, but we already knew that. Gonna need to find one of my other devices, or maybe go through a VM.
    Adam86
    2024-01-14, 09:11 AM
    (2024-01-13, 01:46 PM)mcarlton00 Wrote: Still haven't found any better way to get a nightly running on my main dev workstation.  I was able to get Kodi 21-beta2 working by going through flatpak, but still haven't been able to successfully build nightly.  So I can now confirm that things are working as expected in beta2, but we already knew that.  Gonna need to find one of my other devices, or maybe go through a VM.
    Sorry, but I may be getting the wrong end of the stick here, but if running Windows would it now just be a case of downloading the nightlies via https://mirrors.kodi.tv/nightlies/windows/win64/master/
    Again I maybe misunderstanding here.
    mcarlton00
    2024-01-14, 01:28 PM
    I'm not running windows.  I haven't ran windows on any of my devices in probably 10 years.  I'm running arch linux, which team kodi doesn't publish a nightly package for.  That's why I need to either find one of my Pis or run a VM so I can actually install one of the nightly packages
    Adam86
    2024-01-14, 04:37 PM (This post was last modified: 2024-01-14, 04:37 PM by Adam86.)
    Completely understand now, cheers for explaining :-)
    tmsrxzar
    2024-01-22, 03:54 PM
    there was acknowledgement by team-kodi of "A" (singular) issue with database upgrading on nightly versions, whether or not it pertains to this subject is uncertain but it is compelling
    https://forum.kodi.tv/showthread.php?tid=375938
    axionman
    Country:Mexico
    2024-02-17, 07:06 AM
    just updated Kodi from 21 beta 2 to beta 3 and now I get the same issue:
    Jellyfin extension seems to identify all movies when updating the media library, but movies sections stays empty.
    TV shows section and music is not impacted however.
    I tried to uninstall and reinstall Kodi, but same result Slightly-frowning-face
    mcarlton00
    2024-02-17, 10:15 PM
    The addon hasn't been updated to reflect the database changes in newer versions of Kodi yet. As far as I'm aware, the last compatible version was 21 beta2
    mcarlton00
    2024-02-25, 08:44 PM
    Just updating here as well, I believe I've narrowed down what changes need to take place, however since I still can't get Kodi 21 to build in any sort of reasonable way I can't actually test the required changes and I'd be devving blind.
    Current status can be found in the github issue: https://github.com/jellyfin/jellyfin-kod...1960666033
