    Jellyfin Forum Support Troubleshooting Networking & Access Need help to configure remote
    Fab84
    Country:France
    2025-08-28, 12:13 PM
    Hello. I would like help because I can't do what I want...
    I have an Asustor NAS on which my media are.
    I have an Android TV (LG) on which Jellyfin is installed.
    I have an Android smartphone and I would like to be able to navigate my library on the smartphone to launch a movie on the TV directly without casting.
    I would like the smartphone to serve as a remote control so that the TV goes to find the NAS and plays it.
    How can I do this? I tried Yatse but I can't...
    Thank you in advance for your help and if there is any other information needed, let me know.
    I'm french and used google translate, I hope it's well...
    2025-08-28, 05:50 PM
    https://forum.jellyfin.org/t-remote-cont...46#pid3746
    In other words, you find what you want to play and use "play to". I believe you have to enable remote control of devices.
    Fab84
    Country:France
    2025-08-31, 03:15 PM
    Thanks. I tested it and unfortunately I can't control the jellyfin on my Android TV this way, it doesn't work... Any other ideas?
