    Jellyfin Forum Support Troubleshooting Need Help with Setting Up Live TV using Cabernet on Jellyfin
    Elle221LL
    2023-12-03, 05:24 PM
    Hey all,
    I'm quite new to setting up live TV and I'm trying to get it working with Cabernet in Jellyfin. Cabernet is a tool for controlling IPTV streams and works with plugins like DaddyLive, Pluto TV, XUMO, and supports M3U/XMLTV.XML files (useful for SamsungTV, STIRR, DistroTV, Plex TV, etc.).
    I followed the Docker setup steps from their GitHub (https://github.com/cabernetwork/cabernet) but I'm hitting some snags. Here's my progress:
    Docker Compose Setup: Did this part successfully:
    version: '3'
      cabernet:
        image: ghcr.io/cabernetwork/cabernet:latest
        ports:
          - "6077:6077"
          - /mnt/portainer/cabernetworkConfused-faceapp/data
    Got it up at http://192.168.0.101:6077/
    Plugin Installation: Installed DaddyLive from the plugins section.
    Enabling Stream Providers: Turned it on and saved the changes.
    Restarting via Web Interface: Restarted Cabernet through its web interface.
    Next, in Jellyfin:
    Tried to add an M3U tuner in Live TV.
    Entered URL: http://192.168.0.101:6077
    Now, I'm stuck with this error:
    "Alert: There was an error saving the TV provider. Please ensure it is accessible and try again."
    I even checked out this Reddit post (https://www.reddit.com/r/selfhosted/comments/17pq1ku/how_is_everyone_doing_livetv_self_hosted_in_2023/) hoping to find some guidance on setting it up correctly, but no luck. Most discussions don't get into the nitty-gritty of setup.
    As someone completely new to live TV setups, I'm at a bit of a loss. Any advice, tips, or step-by-step guidance would be really appreciated.
    2023-12-03, 05:58 PM
    We would need to see your logs, assuming this is a Jellyfin problem.
    Honestly, you might have better luck on TVHeadEnd's forum.
    https://github.com/cabernetwork/cabernet#6-forum
    topnomi
    2023-12-04, 02:29 AM
    the containers don't see the host at it's lan ip address, they see it in a separate docker network, and you cannot assume what address they will use. If you set a container name in the compose, you can use that name as a hostname to connect to each other.
    SilveryAbaba
    2024-11-04, 08:32 PM
    (2023-12-04, 02:29 AM)topnomi Wrote: the containers don't see the host at it's lan ip address, they see it in a separate docker network, and you cannot assume what address they will use.  If you set a container name in the compose, you can use that name as a hostname to connect to each other.
    I just got mine set up like that (imgur link)
    but then every time my server restarts I'll have to manually reinput the docker ip for cabernet (172.18.0.4 here). Is there a way to input this automatically?
    2024-11-04, 09:40 PM
    Does Jellyfin start before cabernet?
    SilveryAbaba
    2024-11-05, 04:11 PM
    (2024-11-04, 09:40 PM)TheDreadPirate Wrote: Does Jellyfin start before cabernet?
    Currently there is not a specific order, besides Jellyfin depending on caddy, so it may start after cabernet? I wouldn't mind changing the order if that could help.
    2024-11-05, 05:28 PM
    You could add cabernet as a depends_on for Jellyfin. To ensure it is up before Jellyfin starts. I'm ASSUMING the issue is that Jellyfin starts before cabernet.
    SilveryAbaba
    2024-11-06, 12:49 PM
    (2024-11-05, 05:28 PM)TheDreadPirate Wrote: You could add cabernet as a depends_on for Jellyfin.  To ensure it is up before Jellyfin starts.  I'm ASSUMING the issue is that Jellyfin starts before cabernet.
    I added it as a depends_on yesterday, and when docker started today the ip addresses did their normal roll up, while jellyfin retained the old IP's so behavior did not change.
    2024-11-06, 02:20 PM
    Can you share your full jellyfin log via pastebin?
    SilveryAbaba
    2024-11-06, 08:05 PM
    (2024-11-06, 02:20 PM)TheDreadPirate Wrote: Can you share your full jellyfin log via pastebin?
    Sure, I had to trim a LOT because it was exceeding pastebin's limit. It seemed like a bunch of repeat items though so I hope you see something pertinent there.
    https://pastebin.com/75mwGfxN
