    Jellyfin Forum Support Troubleshooting No plugins avaible and posters not loading
    ProfiloMultimedia
    2024-08-07, 02:11 PM
    Hi everyone, new here, just did a fresh installation of Jellyfin and i can't access the plugins catalogue.
    Log says:
    [2024-08-07 15:47:55.727 +02:00] [ERR] An error occurred while accessing the plugin manifest: "https://repo.jellyfin.org/files/plugin/manifest.json"
    System.Net.Http.HttpRequestException: No route to host (repo.jellyfin.org:443)
    ---> System.Net.Sockets.SocketException (113): No route to host
      at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
      at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)
      at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|285_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken)
      at Jellyfin.Networking.HappyEyeballs.HttpClientExtension.AttemptConnection(AddressFamily addressFamily, SocketsHttpConnectionContext context, CancellationToken cancellationToken)
      at Jellyfin.Networking.HappyEyeballs.HttpClientExtension.OnConnect(SocketsHttpConnectionContext context, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
      at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
      at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
      at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
      at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.<SendCoreAsync>g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
      at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.<SendCoreAsync>g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
      at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
      at System.Net.Http.Json.HttpClientJsonExtensions.<FromJsonAsyncCore>g__Core|12_0[TValue,TJsonOptions](HttpClient client, Task`1 responseTask, Boolean usingResponseHeadersRead, CancellationTokenSource linkedCTS, Func`4 deserializeMethod, TJsonOptions jsonOptions, CancellationToken cancellationToken)
      at Emby.Server.Implementations.Updates.InstallationManager.GetPackages(String manifestName, String manifest, Boolean filterIncompatible, CancellationToken cancellationToken)
    I can access the repository URL via browser.
    In addition every media does not load the poster, instead it has an extracted thumbnail.
    OS is Ubuntu Server 24.04 freshly installed.
    Thanks in advance.
    2024-08-07, 02:32 PM
    Try turning off IPv6 in the OS.
    ProfiloMultimedia
    2024-08-07, 04:07 PM
    I tried but nothing seems to change, still empty catalogue and no posters
    2024-08-07, 05:03 PM
    What did you do to disable IPv6? Something like the steps outlined in this link?
    https://itsfoss.com/disable-ipv6-ubuntu-linux/
    sudo sysctl -w net.ipv6.conf.all.disable_ipv6=1
    sudo sysctl -w net.ipv6.conf.default.disable_ipv6=1
    sudo sysctl -w net.ipv6.conf.lo.disable_ipv6=1
    ProfiloMultimedia
    2024-08-07, 07:30 PM
    Yes, as shown in the image i've added those strings in the /etc/sysctl.conf file.
    I'm sorry to bother you with this, but i've already tried numerous solutions, i reinstalled the OS, changed it, purged Jellyfin and reinstalled it so i'm quite going mad over this.
    2024-08-07, 07:34 PM
    Can you share your full jellyfin log via pastebin? And how did you install Jellyfin? Directly on Ubuntu or as a docker container?
    ProfiloMultimedia
    2024-08-08, 02:08 PM
    Here they are, yesterday's log from first Jellyfin startup and today's log.
    https://pastebin.com/bYE1bAN5
    https://pastebin.com/K5Jkc0z9
    I installed Jellyfin directly on ubuntu via curl
    found on
    https://jellyfin.org/docs/general/installation/linux/
    Thanks again for yout time
    2024-08-08, 04:27 PM
    What is the output of these two commands?
    sudo ip a
    sudo route -vn
    ProfiloMultimedia
    2024-08-08, 04:37 PM (This post was last modified: 2024-08-08, 04:50 PM by TheDreadPirate. Edited 1 time in total.)
    Results below:
    server@server:/$ ip a
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
          valid_lft forever preferred_lft forever
    2: enp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
        link/ether <MAC Addr> brd ff:ff:ff:ff:ff:ff
    3: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
        inet 192.168.1.44/24 brd 192.168.1.255 scope global wlp3s0
        inet6 <IPv6 address>/64 scope global dynamic mngtmpaddr noprefixroute
          valid_lft 86331sec preferred_lft 86331sec
        inet6 fe80::1ad6:c7ff:feaf:8b23/64 scope link
    server@server:/$ sudo route -vn
    Kernel IP routing table
    Destination    Gateway        Genmask        Flags Metric Ref    Use Iface
    0.0.0.0        192.168.1.1    0.0.0.0        UG    0      0        0 wlp3s0
    192.168.1.0    0.0.0.0        255.255.255.0  U    0      0        0 wlp3s0
    Honestly i think it's something wrong about the DNS configuration. When i installed the OS i set a static IP address via the yaml file in /etc/netplan:
    # This file is generated from information provided by the datasource.  Changes
    # to it will not persist across an instance reboot.  To disable cloud-init's
    # network configuration capabilities, write a file
    # /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
    # network: {config: disabled}
    network:
        ethernets:
            enp4s0:
                dhcp4: no
                optional: true
        version: 2
        wifis:
            wlp3s0:
                access-points:
                    the Wi-Fi SSID
                        password: the wifi password
               dhcp4: no
                addresses:
                  - 192.168.1.44/24
                routes:
                  - to: default
                    via: 192.168.1.1
                nameservers:
                  addresses: [8.8.8.8, 8.8.4.4]
    Probably something similar to this:
    https://forum.jellyfin.org/t-solved-plug...ot-loading
    2024-08-08, 04:53 PM
    It looks you still have a bunch of IPv6 addresses. Have you rebooted or applied the IPv6 changes? To apply them without rebooting you'd use this command.
    sudo sysctl -p
    Before that, we can test something.
    If you run "curl -4 api.tmdb.org" you should get a 301 response. But if you run "curl -6 api.tmdb.org" does it 404 or some other 400 message?
