    Jellyfin Forum Support General Questions Noob here with weird problem regarding DolbyVision transcoding.
    daspunner
    2025-04-21, 01:47 PM (This post was last modified: 2025-04-21, 01:48 PM by daspunner. Edited 1 time in total.)
    Hi y'all!
    I am trying to transcode DolbyVision-content to SDR. In Jellyfins own webplayer they look right but in Kodi with the Jellyfin addons they look green/pink/purple.
    Server and client are on the same machine due to the lack of real HDR/DV-support on the display. Transcoding are done through a RTX3060.
    Sidenote: HDR-content transcoded with Jellyfin works with Kodi but not DV.
    Any ideas?
    /Dave
    pxr5
    2025-04-21, 03:20 PM
    What Dolby Vision Profile is the the file you are playing back? As for Kodi it has a setting under Video Processing (Settings - Player - Videos - Dolby vision compatibility mode) - set to yes, will convert Profile 7 to 8.1 for better compatibility. Also in Video Processing there is a setting to choose what HDR type is allowed - HDR10/DV.
    Jellyfin1 - 10.10.11 Synology NAS (transcoding off)
    Jellyfin2 - 10.10.711 Minix ZX100-0db MiniPC, Intel N100 (transcoding on)
    Storage - x3 Synology NAS (22TB)
    Reverse Proxy - Caddy v2 running on a Pi3b+
    2025-04-21, 04:03 PM
    Is Kodi configured to locally tone map? What you've described tells me this is a Dolby Vision profile 5 video.
    daspunner
    2025-04-21, 04:15 PM
    Yes it is DV profile 5. So the problem is in Kodi? I think so too. Even the Jellyfin-client on my Android shows correct colors.
    pxr5
    2025-04-21, 04:37 PM
    In Kodi Both jellyfin-kodi and jellycon have options in the config to transcode. Kodi itself can't transcode anything.
    daspunner
    2025-04-21, 04:57 PM
    (2025-04-21, 04:37 PM)pxr5 Wrote: In Kodi Both jellyfin-kodi and jellycon have options in the config to transcode.  Kodi itself can't transcode anything.
    Are we talking of Kodi in Windows now? Checked both addons and I can't find any setting for transcoding.
    daspunner
    2025-04-21, 05:15 PM
    Never mind! I found it!
    The videos are a little dark tough. Nothing I can't fix with brightness setting in Kodi but can adjust something so the transcoded streams are brighter from start? Transcoding settings in Jellyfin server perhaps?
    2025-04-21, 05:44 PM
    Did you change any of the transcoding settings for tone mapping? By default the output of a tone mapped transcode should be pretty close in brightness to a native SDR video.
    daspunner
    2025-04-21, 08:57 PM
    No I did not change any parameters regarding transcoding. Since I know so little about transcoding I just followed the guide stating that best setting for new users was to set algorithm to BT.2390.
    Are there any places that I could read a little bit more about Jellyfin and transcoding? Their documentation is very basic.
    2025-04-22, 12:28 PM
    Fiddled around with some settings and couldn't find a way to reliably increase brightness that did make it worse for other content.
