    Jellyfin Forum Support General Questions old Mac mini transcoding settings
    Looking for suggestions on transcoding settings.
    BryanB
    2025-04-14, 12:17 AM
    (2025-04-13, 09:40 PM)TheDreadPirate Wrote: Can you share the ffmpeg log from the failed playback?  That all looks right for your CPU.
    https://pastebin.com/XWj4sr4L
    2025-04-14, 01:04 AM
    I need the ffmpeg log. FFmpeg.Transcode{Insert long string}.log
    BryanB
    2025-04-14, 03:05 AM (This post was last modified: 2025-04-14, 03:08 AM by BryanB. Edited 1 time in total.)
    (2025-04-14, 01:04 AM)TheDreadPirate Wrote: I need the ffmpeg log.  FFmpeg.Transcode{Insert long string}.log
    How's this?
    https://pastebin.com/r2ivDApG
    maybe not a great way to encode the video anyway? avi is a bit odd these days, isnt it? I could just run them through handbrake maybe.
    2025-04-14, 12:41 PM (This post was last modified: 2025-04-14, 12:41 PM by TheDreadPirate.)
    The only other suggestion is check if Metal is installed.
    https://jellyfin.org/docs/general/admini...ion/apple/
    Not sure if that is strictly necessary or not. Not sure what else to suggest beyond this.
    I am at my limit regarding this topic since I don't have any Macs. But it may just be that Apple Videotoolbox no longer supports your GPU.
    BryanB
    2025-04-14, 05:28 PM
    (2025-04-14, 12:41 PM)TheDreadPirate Wrote: The only other suggestion is check if Metal is installed.
    Metal is part of the OS, so I don't think there is a thing as, making sure its there.
    I may use a different computer. I have an old 7th Gen i5, and an AMD R5 low profile card. Or I can Handbrake everything and remove AVI's.
    2025-04-14, 06:11 PM
    The 7th gen Intel i5 would be what I'd choose of the available options.
